Thread: Constant 5v Source Anywhere?
Results 1 to 8 of 8
  1. #1 Constant 5v Source Anywhere?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I Need a regulated 5v source for my Aeroforce air temperature sensor kit, any suggestions? other than buying a 12v to 5v DC regulator?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Constant 5v Source Anywhere?
    Add a circut dealio to a fuse in the glove box.
    I pick the IGN fuse or the radio, both get power when the car is on.
  3. #3 Re: Constant 5v Source Anywhere?
    Nebraska
    I thought that was a 12v source no?
  4. #4 Re: Constant 5v Source Anywhere?
    Hmm, I guess you're right.
    Then I'm not sure were you will get just 5v unless you tapped into a sensor that only is supplied up to 5v.
  5. #5 Re: Constant 5v Source Anywhere?
    Nebraska
    The EGR is a 5V circuit right? if so is it a steady 5V? or 1-5V?
  6. #6 Re: Constant 5v Source Anywhere?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by 94GrandPrixSE View Post
    It's 0-5v
  7. #7 Re: Constant 5v Source Anywhere?
    There are regulated 5+'s off the pcm. You'd need to find the thread with the pcm pinouts and find the right circuit
  8. #8 Re: Constant 5v Source Anywhere?
    Kemmerer, Wyoming
    I thought there might be a 5V source on the obd2 plug, but I'm not sure. do you guys know?
  1. Constant 12v Source Locations
    By HighOctaneRacing in forum Introductions/Noob Questions
    Last Post: 12-02-2013, 12:54 AM
  2. constant ticking under dash!!!!
    By canadian2000gtp in forum General Grand Prix Discussion
    Last Post: 09-07-2013, 05:09 PM
  3. Need help locating 12v constant and 12v ignition
    By acidcrashdburnd in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2013, 08:46 PM
  4. Constant Power Only - Aftermarket Stereo
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 07-22-2012, 08:42 PM
  5. Damn constant repairs!!!
    By WhiteGT in forum The Rant Forum
    Last Post: 05-23-2009, 05:05 PM
