Thread: are these springs the blue ls6 springs people are talking about?
Results 1 to 18 of 18
Threaded View
vikesfan are these springs the blue... 03-15-2015, 09:34 AM
djudge1970 Re: are these springs the... 03-15-2015, 10:24 AM
HighOctaneRacing Re: are these springs the... 03-15-2015, 10:28 AM
Booba5185 Re: are these springs the... 03-15-2015, 11:05 AM
vikesfan Re: are these springs the... 03-15-2015, 11:11 AM
Booba5185 Re: are these springs the... 03-15-2015, 11:33 AM
vikesfan Re: are these springs the... 03-15-2015, 11:57 AM
vikesfan Re: are these springs the... 03-15-2015, 12:00 PM
Booba5185 Re: are these springs the... 03-15-2015, 12:50 PM
vikesfan Re: are these springs the... 03-15-2015, 02:26 PM
vikesfan Re: are these springs the... 03-15-2015, 01:59 PM
Booba5185 Re: are these springs the... 03-15-2015, 02:47 PM
vikesfan Re: are these springs the... 03-15-2015, 05:24 PM
REDCRAPGP Re: are these springs the... 03-15-2015, 05:53 PM
Booba5185 Re: are these springs the... 03-15-2015, 06:41 PM
NebTurboST5 Re: are these springs the... 03-15-2015, 06:51 PM
Booba5185 Re: are these springs the... 03-15-2015, 07:57 PM
vikesfan Re: are these springs the... 03-15-2015, 11:10 PM
  1. #1 are these springs the blue ls6 springs people are talking about?
    Jan 2014
    minnesota
    I have acquired a set of beehive springs that have a blue stripe on them that look very similar to the yellow springs. I am curious if they are the same spring or which one I should use. I have a set of the blue stripe and a set of the full yellow painted springs
    I am putting on my gen 5 top swap top, 2007 n/a block, stock cam, stock everything. However in the near future I will be planning on upgrading the rockers I believe to either 1.8 or 1.9, so I would like to upgrade the springs while I've got the heads off because the rockers are easy to do with the engine together.
    I would also like to know if it is ok to run the stock retainers and clips. I have read in many places that it's OK and it's not okay, but many of the threads that I found were from the early to mid 2000 and some of them were newer like 2013 or so. I could not find a definitive answer one way or the other for the stock retainers and stock clips.
    Edit to add pic...
  1. Replies: 14
    Last Post: 11-23-2013, 04:23 PM
  2. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
