Thread: Someone take a picture of your passenger side door hinges
Results 1 to 7 of 7
  1. #1 Someone take a picture of your passenger side door hinges
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    While I'm fixing all the issues on this GP, I am revisiting this old one. Since I've had the car, the passenger side door does not stay open. There is no resistance in the passenger door hinge at the med and wide open positions, so the door will swing shut. I noticed today that the spring on the passenger side is on the BOTTOM, but the spring on the drivers side is on the TOP. This doesn't look right. The spring is never in contact with the hinge mechanism so it offers no resistance. I took a few pictures.
    I think what happened was the car was in an accident before I owned it, and the body shop installed the hinges incorrectly. Can someone take a picture of your passenger door hinges and post for comparison?
    Drivers Side
    Drivers Side spring closeup
    Passenger Side
    Passenger Side spring closeup
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: Someone take a picture of your passenger side door hinges
    St. Louis
    This is the lower hinge on the passenger side front door of my 4 door 00 GP GT, and yes it keeps the door open to a point:
  3. #3 Re: Someone take a picture of your passenger side door hinges
    SE Level Member zbban1's Avatar
    May 2014
    Mi
    Pardon the dirt, I was in the process of cleaning the doors up...lol. This is the lower hinge on the passenger side on my '97 2 door GTP. What I can see between the 3 pics is the fact that the "arm" that goes between your spring and that post that sticks up from the top of the hinge (sorry, don't know the proper name for it) is more worn than either of ours. Maybe that has something to do with it? My door opens and shuts properly and stays put in both the middle and wide open positions.
  4. #4 Re: Someone take a picture of your passenger side door hinges
    Apr 2015
    Columbus, OH
    The orientation is different because its on opposite sides of the car. They use the same part, just flip it depending what side its on. I think that pin that the bracket positive locks into is supposed to roll as the bracket slides on it. Yours probably rusted in place which caused the bracket to grind on it as you open/close the door which eventually ground enough off that it won't hold the door.
    Top Swapped 01 Imp
  5. #5 Re: Someone take a picture of your passenger side door hinges
    id see if i could free up that hinge point for that lever. it maybe rusty and holding the spring from pushing it fully to the post there.
  6. #6 Re: Someone take a picture of your passenger side door hinges
    Apr 2011
    Elk Rapids, Michigan
    My 2000 GT driver's side had the same problem. I soaked the pivot point with a penetrating oil such as PB Blaster. It should free up but may take a few days of repeat applications. Make sure you do the same to the roller that contacts the detent bar so that it will rotate. When it's freed up use a good lubricating grease. Repeat every few months.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  7. #7 Re: Someone take a picture of your passenger side door hinges
    Cleveland, OH
    Quote Originally Posted by ExLimey View Post
    Yep this is what I did. PB Blaster and banged on it with a hammer. Freed it up enough to actual make contact with the roller. I soaked it all with white lithium grease. Will revisit in a few weeks with more PB Blaster/hammer.
    Thanks everyone for your ideas and photos.
    Jason
  1. Passenger side door pins
    By blortz in forum General Grand Prix Discussion
    Last Post: 09-18-2014, 03:53 PM
  2. Replies: 0
    Last Post: 07-12-2013, 10:22 AM
  3. Gpo's, passenger side door panel lense.
    By osiris94ej in forum Wanted To Buy - Parts
    Last Post: 02-20-2013, 09:43 AM
  4. Passenger side door wont open
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-05-2009, 01:08 PM
