Thread: Nasty Plugs Look!
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 191
  1. #21 Re: Nasty Plugs Look!
    it does. no other way around it.
    why whats up now?
  2. #22 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    car just dies even if in park from idle to 2k it will die. i read on here it could be cps and i have a extra from a l67 im rebuilding for the car
  3. #23 Re: Nasty Plugs Look!
    so it starts then stalls like 10 seconds later, sorta like it ran out of gas?
    if so thats the hi speed fuel resistor gone bad.
  4. #24 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ya its kinda like that but then sometimes i can drive it for a bit befor it dies.. gota take my wife to the store ill bbl
  5. #25 Re: Nasty Plugs Look!
    give this a shot.
  6. #26 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    replaces that relay or bend out the tab? sorry for being dumbi just wanta make sure and thanks for your time and help
  7. #27 Re: Nasty Plugs Look!
    bend the tab out like it says in the pic. that bypasses the resistor. if it runs the resistor is bad. most run it like that forever.
  8. #28 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ok thanks..you need to be careful you know to much for your own good. the mechanics mafia is going to get you.. may want to check for a black van outside your house
  9. #29 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ill have to try it after work tomorrow it will wake my neihbor
  10. #30 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    i started the car today. I let it idle for 5 mins then turned it off.so maybe its good. ill grab another resistor next time im at pick n pull. thanks scotty
  11. #31 Re: Nasty Plugs Look!
    its inside the fender by the battery. its only on a gtp. not sure if a regal gs one will work or not.
  12. #32 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ya in the engine bay fuse box got it. will bending the tab out and running it like that put added stress on the fuel pump? picknpull has a few gtps in there yard
  13. #33 Re: Nasty Plugs Look!
    Antioch, IL
    no, people have run it like that for many a years with no problems.
    2009 Challenger SRT8
    Expert at being gay.
  14. #34 Re: Nasty Plugs Look!
    some never fix it. some do. its your call in the end. its just running the pump in hi speed mode full time. dont seem to wear on the pump.
  15. #35 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    ok cool thanks guys
  16. #36 Re: Nasty Plugs Look!
    Jan 2015
    ohio
    Check your vacuum line from your throttle body to your map sensor. Sounds too simple to be true, I know. Replace the crappy plastic ones with rubber. I bet that has something to do with it.
  17. #37 Re: Nasty Plugs Look!
    On the resistor.. it's the same GP or Regal.
    It's this connector
    Here's a picture of the whole car
    and the wiring goes behind the washer tank
    Because GM never thought it would burn up, three bolts hold the tank in place, then one more and the resistor can be removed
    However.. the replacement from GM gets bolted to the center top of the firewall. Reality is.. many of us have bent the tab and smiled. Since we have a pressure regulator, that takes care of the issue. A fuel pump hotwire kit runs the pump in high speed all the time. So there's no worries overall of running in high speed mode. My Regal has been that way for 2+ years now.
    CPS is Camshaft Position Sensor to be technical. Most here will know you are talking about the CKPS which is the CranKshaft Position Sensor. And yes.. you need to pull the balancer.
    Here's the how to with pics.
    http://www.grandprixforums.net/threa...highlight=easy
  18. #38 Re: Nasty Plugs Look!
    Antioch, IL
    why not just chop the resistor off and twist the 2 wires together? hotwire kit just gives you a plug with a wire that just loops back to the other wire.
  19. #39 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    my washer bottle is inside the car and the resistor is just floating around. i didnt really know what it was i thought it was a pump for the washer fluid. ohmymy
  20. #40 Re: Nasty Plugs Look!
    Oct 2014
    portland oregon
    thanks for the link to the CKPS bill
  1. Nasty gunk all over...
    By WarStryker13 in forum General Grand Prix Discussion
    Last Post: 11-05-2014, 11:45 AM
  2. Nasty Rumble
    By KitRae in forum Engine
    Last Post: 11-15-2012, 08:33 AM
  3. nasty s4, mazdaspeed 3, and gti
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 12-17-2009, 01:13 AM
