Thread: Coolant temp low code
Results 1 to 5 of 5
  1. #1 Coolant temp low code
    Nov 2013
    lville
    I got a code that said the coolant temp is consistently low. ( cant remember the code #) so i replaced the thermostat and the temp sensor and it didnt fix the issue.
    The coolant temp fluctuates with the outside temp. the cooler day, the cooler the gauge reads and vise versa.
    any suggestions?
    thanks
    2006 grand prix gt 125k miles
  2. #2 Re: Coolant temp low code
    Very possible to get a faulty thermostat.
    Or you got a 180º instead of the factory 195º.
  3. #3 Re: Coolant temp low code
    St. Louis
    Could also be a bad coolant temp sensor, as they're known to be bad out of the box, sometimes 2 or 3 in a row before you find a good one. Did you clear the CEL after replacing the parts?
  4. #4 Re: Coolant temp low code
    Pennsylvania, USA
    The temp sensor should read a certain resistance in ohms at specific temperatures, if you have a multimeter you can verify whether or not it's the sensor.
    212 F = 177 ohms
    194 F = 241 ohms
    176 F = 332 ohms
    68 F = 3520 ohms
    41 F = 7628 ohms
    32 F = 9420 ohms
    Those are probably the most relevant temperatures in your case since I'm not sure if you're working on this inside or outside. Operating temperature will fluctuate above and below 195 F, engine off and cold will be ambient temperature given enough time. If the sensor is good, then try checking over the wiring for any damage.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: Coolant temp low code
    Apr 2011
    Elk Rapids, Michigan
    Sounds like OBD2 code P0128. I was getting this code and my coolant temps were all over depending on the outside temperature and driving conditions. I'd get an SES light every few days. I finally replaced the thermostat and it fixed my problem. When I looked it up on Google, one site said it could be these problems.
    - Leaking or stuck open thermostat
    - Low engine coolant level
    - Insufficient warm up time
    - Faulty engine coolant temperature sensor
    - Engine coolant temperature sensor harness is open or shorted
    - Engine coolant temperature sensor circuit poor electrical connection
    Read more: http://engine-codes.com/p0128.html#ixzz3NzyufFYQ
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  1. coolant temp sensor
    By billyt in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2014, 12:19 PM
  2. coolant temp sensor
    By PaJeff in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 08:10 AM
  3. Intake temp vs coolant temp.
    By chicagochuck in forum General Tech Discussion
    Last Post: 09-30-2012, 08:44 PM
  4. Coolant Temp Isuue
    By Codester in forum General Tech Discussion
    Last Post: 10-21-2011, 09:28 PM
  5. coolant temp
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 07-08-2010, 01:21 AM
