Thread: How to remove this weird screw/bolt
Results 1 to 10 of 10
  1. #1 How to remove this weird screw/bolt
    SE Level Member GrandPrick97's Avatar
    Aug 2014
    Lynchburg, VA
    Hey guys I'm in the process of removing my damaged drivers side fender and the last bolt I need to remove is very strange and has me stumped.
    please help, I can't drive until I get my new fender on
  2. #2 Re: How to remove this weird screw/bolt
    hangover park IL
    pop rivet
    drill it or grind it
    ~James~ Psychotic Gearhead
  3. #3 Re: How to remove this weird screw/bolt
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    pop rivet
    X2 it's just a wide flanged pop rivet. 1/8 drill bit will take care of it.
    7"
  4. #4 Re: How to remove this weird screw/bolt
    Aug 2014
    Lynchburg, VA
    pop rivet
    How do I drill it? Don't have a grinder
  5. #5 Re: How to remove this weird screw/bolt
    with a drill bit the same size as that center pin, drill it out.
  6. #6 Re: How to remove this weird screw/bolt
    isnt that holding plastic on one side a claw hammer will pull them out if its the one im thinking of.
  7. #7 Re: How to remove this weird screw/bolt
    Aug 2014
    Lynchburg, VA
    I just looked it up, I guess I have to drill right through it, am I correcrt? Can I replace it with a nut and bolt once I put the new fender on? Thanks for the help so far
  8. #8 Re: How to remove this weird screw/bolt
    yup drill out replace with nut bolt and a few washers no big deal.
  9. #9 Re: How to remove this weird screw/bolt
    Aug 2014
    Lynchburg, VA
    Thanks for the fast replies, you guys are awesome
  10. #10 Re: How to remove this weird screw/bolt
    make sure the area is clear for the drill bit on the other side. you dont want to drill other stuff.
  1. 1997 gp glove box screw/bolt size
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-27-2013, 04:07 PM
  2. Best way to remove broken bolt
    By tms8582 in forum Brakes/Suspension/Chassis
    Last Post: 12-14-2011, 02:48 PM
  3. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
