Thread: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
Results 1 to 8 of 8
  1. #1 Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    Dec 2014
    Belarus, Minsk
    Hi!
    My name is Siarhei and i'm novice on this forum.
    Sorry for the my english - it not so good as i want
    I have a Pontiac Grand Prix SE auto with a 2.8 v6 engine.
    This is the car photo before rebuild starting.
    Now the car is under reconstruction, but the old 2.8 engine is really bad... So i plan to swap new engine into the Pontiac. I founded a 3400 engine with transmission from the 2000 Chevrolet Impala.
    Refer to the Photo below:
    The engine is in good condition, so i believe the Pontiac with this engine could be the good project.
    As i can see from this thread somebody already did the same swap
    http://60degreev6.com/forum/showthre...peed-3400-swap
    But i cannot find the details of this process.
    So maybe you can help me and say, what additional parts i need? Do i need a Impala harness and impala engine ECU? Is it possible to combine Pontiac harness with Impala engine ECU?
    Thanks!
  2. #2 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
  3. #3 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    Dec 2014
    Belarus, Minsk
    Yes, i read thes thread but it describe only turbo installation but nothing about 3400 swap
  4. #4 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    You definetly need the ecu from the impala and the wiring harness i can definetly tell you that. You might find more info in the beretta forums. Guys there have done very similar swaps to there late 80s berettas with the 2.8.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  5. #5 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    Dec 2014
    Belarus, Minsk
    Quote Originally Posted by Silversurfer Gio View Post
    Thanks for the info!
    I'm thinking about impala ecu and wiring harness too, but the impala has the different harness for the engine and for the dash while the Grand Prix has the one harness for the engine and for the dash. So i should splice the harness from impala with harness from grand prix and it scares me)
    Btw, i will try to find info on the beretta forum
  6. #6 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    your gonna have to run a pcm set up for like a dune buggy or off road car to make the engine run in there. the 3400 runs on obd2, the 88 car does not.
    so grab the harness, and the pcm.
  7. #7 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    Dec 2014
    Belarus, Minsk
    The beretta forum is awesome!
    Here is the full swap info
    http://www.v6z24.com/howto/3400/intro
  8. #8 Re: Swap 3.4 from Impala 2000 to the Pontiac Grand Prix 88 2.8
    Mar 2012
    NC
    It IS possible to run the 3.4 with all the 2.8 stuff...just swap over all the 2.8 crap to the 3.4 block. It'll run just fine that way.
  1. supercharged motor swap 04 impala to 04 grand prix
    By alreadytooken in forum Engine
    Last Post: 05-12-2013, 10:49 PM
  2. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
