Well...harness damage means replacement which requires side cover removal...again.
Well i added some lucas and for some reason after driving it a few days the issues hasn't stopped almost. but a lot better. so maybe it giggled it into place or something.
Well now that the car is working again. time to visit a past issue that is still showing.
I had some space to wot the other day but boosted gauge never got above 5/8 full... With a little hesitation on accel. Is was like a random hesitaion but i keep it WOT and it still keep gaining speed at a decent rate. but still feel like its missing a little more. What should i look at next?
Back to the code game
P0142 02 Sensor Heater Circuit Bank 1 sensor 2 <----- Where is this sensor located?
P0756 Shift Solenoid B Performance or Stock Off <---- how do i fix this issues???
At least on down to only two codes! Please Help! Thanks anyone!
bank one up stream is the o2 in the rear manifold, you know the one that sorta blocks one spark plug. you need a o2 socket to remove it. its a 7/8 th's socket.
Winter has been tough on her. Front bumper got all cracked up and the driver side front fender got caught on door and bent in. No pics of that yet but i guess ill be changing the front bumper and front fender this summer and crack in hood.
http://i1033.photobucket.com/albums/...psohgzyn4i.jpg
http://i1033.photobucket.com/albums/...pstiyvpl6z.jpg
you sure thats the right code? its for bank one sensor 3..... http://engine-codes.com/p0142.html
likely a bad sensor, its the one after the cat. http://www.obd-codes.com/p0141
