Thread: help with EVAP Vacuum switch
Results 1 to 8 of 8
  1. #1 help with EVAP Vacuum switch
    Oct 2014
    portland oregon
    Hi guys. been having some problems with my 97 GTP. So I have been going through the different vac lines and connections to see if there is a leak. I pulled the rubber hose off the evap vacuum switch(the one that goes to the purge canister) and it was plugged with some shiny black flakes and when I crushed them up they smelled chemically not like gas. Could these have come from the purge canister? Cleared out the hose the car still isnt running great. Any tips would be great. Thanks guys
  2. #2 Re: help with EVAP Vacuum switch
    Oct 2014
    portland oregon
    nothing? anyone anything.. penny for your thoughts lol thanks in advance
  3. #3 Re: help with EVAP Vacuum switch
    Oct 2013
    scituate ma.
    While your in that area check your fuel filler pipe. If there are any rotted holes it will throw an evap code.
  4. #4 Re: help with EVAP Vacuum switch
    Oct 2014
    portland oregon
    ok thanks man i did look at it. it is in rough shape but there are no holes that i could see
  5. #5 Re: help with EVAP Vacuum switch
    Oct 2013
    scituate ma.
    Quote Originally Posted by wowitsfast View Post
    I have been looking for my leak and cant find it either. I going to have a smoke test done on my 97 and get that annoying light off.
  6. #6 Re: help with EVAP Vacuum switch
    Oct 2014
    portland oregon
    does a smoke test do an entire vacuum system? like fuel filler into the engine bay or just engine bay vacuum lines. What do you think it cost?
  7. #7 Re: help with EVAP Vacuum switch
    Oct 2013
    scituate ma.
    I think its usually in the $100.00 range. It will test all of it.
  8. #8 Re: help with EVAP Vacuum switch
    Oct 2014
    portland oregon
    100 bucks isnt bad i could spend a lot more then that replacing things i dont need to
  1. Evap issue? Vacuum leak?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2014, 11:22 AM
  2. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  3. EVAP Switch, MAP Sensor Bracket. 97 GTP
    By slydoggy38 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2013, 09:01 PM
  4. EVAP canister purge valve vacuum line part number
    By Freimuth in forum General Tech Discussion
    Last Post: 04-18-2012, 11:00 AM
