Thread: Backfire Explosion
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 Backfire Explosion
    Jun 2014
    Destin, FL
    So I went to fire up the GTP yesterday and it wouldn't start, I turned the key 3 separate times and at the end of the third try there was a very loud backfire/explosion. I was dazed at this point it was like a scene from archer where he's saying mawp with ears ringing. I left it alone for the night because it was too dark and I was to dazed to want to mess with it. Today when I got around to checking it out I found nothing out of the ordinary under the hood so I turned the key to the on position, I heard the fuel system pressurize and I tapped the key to start and it fired right up. well at this time I instantly could tell the car was louder, I looked under the back at the muffler and this is what I saw
    so I'm kind of at a loss as to what caused this. the back fire was so big it also cracked and broke both taillights.
  2. #2 Re: Backfire Explosion
  3. #3 Re: Backfire Explosion
    Buffalo
    Dude. That's amazing......
  4. #4 Re: Backfire Explosion
    Lmao amazing!
    04 Comp G.
  5. #5 Re: Backfire Explosion
    May 2012
    Where winter never ends
    hahahahahaha thats effing amazing! You got me to bust out in class!
    2000 Regal - Winter Beater
  6. #6 Re: Backfire Explosion
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    LOL
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  7. #7 Re: Backfire Explosion
    ive done that in the past myself.
    only we used to think it was cool to turn the engine off after flooring it, then turn the key back to run,,,,,and boom! it would pop and sound kinda cool. then one time it blew the muffler apart. bummer lol
    needless to say at this point, you had a ton of un used fuel in the exhaust, it blew up when it fired up.
  8. #8 Re: Backfire Explosion
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Little Tuck tape and carpenters glue. Should be good as new.
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  9. #9 Re: Backfire Explosion
    Jun 2014
    Destin, FL
    What's even better is driving it, it reminds me of every local redneck with the muffles cut off their V6 trucks. made me LMAO.
  10. #10 Re: Backfire Explosion
    Mar 2014
    Tucson
    Bwahaha! Best post today!
  11. #11 Re: Backfire Explosion
    Could it be that the Turdy800 actually sounds better like this?
  12. #12 Re: Backfire Explosion
    Jun 2014
    Destin, FL
    Yeah I guess trying to crank on it wasn't a good Idea, I just thought it was being difficult because it was really cold when this took place (about 36*). other then that it hadn't been started in over 36 hours as it's not my DD.
  13. #13 Re: Backfire Explosion
    HUDSON
    That is a neat look inside the stock mufflers, lol. Might want to check your resonator and cat.converter also to make sure they are ok.
  14. #14 Re: Backfire Explosion
    im really surprised it blew it up like that, 2 times worth of injector priming should not do that. some how lots of fuel vapors got blown up.
  15. #15 Re: Backfire Explosion
    Jun 2014
    Destin, FL
    Quote Originally Posted by QUICKSILVER462 View Post
    Yeah I was mostly worried about the flex pipe on the speed daddy headers but it seems so far the only damage is the mufflers. Scotty I'm running a Reptile ECM so I'm not sure if he upped the amount fuel enough at start cycle or not.
  16. #16 Re: Backfire Explosion
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Will you be doing a write-up for your muffler delete?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  17. #17 Re: Backfire Explosion
    This is probably one of the best things I've ever seen on this forum.
    You win.
  18. #18 Re: Backfire Explosion
    Am I seeing that right, you blew up both mufflers?
  19. #19 Re: Backfire Explosion
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    This is great
    2012 F150 STX
    - Gonna be a race truck
  20. #20 Re: Backfire Explosion
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    this is too good... i'm sorry about it but at the same time it is hilarious
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  1. Backfire!
    By GTPJIM in forum Engine
    Last Post: 08-23-2013, 12:55 AM
  2. coolant explosion
    By vandezand in forum General Tech Discussion
    Last Post: 01-03-2013, 07:27 AM
  3. Upper intake explosion.
    By 97gpl36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 01:24 AM
  4. Sounds like a backfire
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 10:07 PM
  5. AC Delco Explosion
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 04-04-2009, 08:00 PM
