Thread: fuel tank capicity
Results 1 to 20 of 20
  1. #1 fuel tank capicity
    Moore,OK
    has anyone ever had a problem with there gas tank not filling up all the way?
    i bought this car about a month ago and filled it up. i drove it about 250 miles and it was low on gas so, i stopped and filled it up. it only took 11.5 gallons. at first i thought it was just the fuel guage not working right so, next time it read low i just ignored it. well needless to say i ran out of gas. went to fill it up...11.5 gal. everything i read says that it should be a 17 gal. tank.
    i guess i shoulden't gripe. its less gas to carry around for that impromptu race but, it sucks having to stop every 250 miles for gas.
    any ideas? i was thinking that it might be a vent problem but everything visible looks good. oh yeah. it's a 99 GTP and i LOVE it.
    http://i343.photobucket.com/albums/o...le_01/1123.jpg
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  2. #2 Re: fuel tank capicity
    Bastard Reptile's Avatar
    Kansas City, MO
    It could absolutely be a vent problem. The fuel capacity is 17 gallons. Might start looking into that issue.
  3. #3 Re: fuel tank capicity
    May 2008
    McHenry IL
    hay messege me about this man i notice this also on my 99 GTP i was pretty low o gas put 12 gallons in her and the pump shut off??? but when i filled it up my gauge was on the F so??? is that right or??
  4. #4 Re: fuel tank capicity
    Apr 2008
    Chillin at the Beach , VA
    It's kinda weird because on my 97 GT, when the fuel gets under a quarter of a tank, the gas hand will move up and down. Sometimes it will stay down long enough for the low fuel light to come on. Stop to put gas in it and only get 12-14 gals in it. You might be having the same problem. Just haven't gotten brave enough to see how much further she'll go once I get to that point to see if the guage is actually f'ing up at that point or she just sucks it down that fast which I dought.
  5. #5 Re: fuel tank capicity
    Moore,OK
    on my 99 when the guage reads around 1/8 of a tank, i can hear the fuel pump cavitating when i come to a stop. it did it so bad that at one stoplight it died on me. it started back up and i made a bee line for the gas station. filled it up and it took 11.5 gallons and the guage read full. i know it's not getting bad milage cause i checked it a couple of times. i'm averaging right at 21mpg.....but i got a heavy foot.
    next time it gets low on gas i'll back it up the ramps and start poking around. i've heard of a simalar problem with jeep wranglers not fillling up all the way because the fill vent tube inside the tank is to long.
    if i don't find anything on the outside i guess i'll pull the pump and take a look on the inside. it will be a good excuse to buy that snap-on borescope i've been wanting.
    i'll let ya'll know what i find
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  6. #6 Re: fuel tank capicity
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    The plastic tanks are slightly larger (01+), but the last time I ran outta gas (long time ago) I took a cell phone pic at the pump completely full couldn't hold another drop lol.... Btw I wish I got 250miles outta 11.5 gallons
    fuel tank capicity Attached Images
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  7. #7 Re: fuel tank capicity
    Feb 2008
    Quote Originally Posted by GTP2K1 View Post
    /\ comes out to about $2.90/Gal .....hmmmm those were the days
  8. #8 Re: fuel tank capicity
    Tampa, FL
    Quote Originally Posted by Blown97 View Post
    Yes it was quite a while back. But saying those were the days is all perspective.... I'm only 24 an I clearly remember paying .99 for premium for about a month in the year 2000 (was typically $1.15~1.20 or so) I was 16 an loving every min behind the wheel.
    If anyone asks me... THOSE were the days.
  9. #9 Re: fuel tank capicity
    SE Level Member dlindeken's Avatar
    St. Paul, MN
    The most I've gotten with my 99 GTP is between 250 and 275 miles and right on the E mark. I have only been able to put 14 gallons in also and I am supposed to have a 17 gallon tank. I haven't tried to put more miles on for fear of running out. Dealer says still 1-2 gallons in the tank, but i dont know.
  10. #10 Re: fuel tank capicity
    Oklahoma
    Crap, you must have taken that pic a long time ago. Thats what, a little under three dollars a gallon? For premium I assume?
  11. #11 Re: fuel tank capicity
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    they actually design cars so that when the gauge reads empty it's not really empty because they don't want you to run out of gas...in this case it's quite possible that at an eighth to a quarter tank there is still 4 or 5 gallons in the tank when you fill up...I once watched a news report where the guy drove over 30 more miles after the needle reached E which had to be at least 2 gallons
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  12. #12 Re: fuel tank capicity
    Moore,OK
    Quote Originally Posted by Chleby View Post
    i know what you're talking about. my dodge truck is set up that way. when the needle points to E i can go about another 20-30 miles but... my gtp is not this way. believe me. when the needle points to E you better find a station NOW. i can even hear the fuel pump cavitating when i come to a stop.
    i know the 4 cyl jeeps had a longer vent tube in the gas tank to make it a 15gal tank. if you cut it down it would make it a 20 gal tank. why they did this is beyond me. i'm with SynS. i would love t have a 20-25gal tank.
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  13. #13 Re: fuel tank capicity
    Oklahoma
    Well they also modify the tanks as well. They will use the same tank across a few lines of cars but change the vent tube I believe it is or something like that so that you can only fill up with so much gas. WHY they find that necessary is beyond me. But I know amongst the Jeep and Rodeo communities there are certain variants that benefit from dropping the tank and modifying this tube or whatever it is.
    Also, if you look at the average range of most vehicle, particularly passenger cars and such, it tends to be around the 450 - 500 mile range. Why this is so, again, Im not sure but it seems purposeful. If it were available, I would put a larger fuel tank in the GTP. Id like to have about a 20 - 22 gallon tank in the thing to be honest. I do enough driving that such a thing would be beneficial to me.
  14. #14 Re: fuel tank capicity
    Banned
    New Port Richey Florida
    My 02's book says that the tanks 17.5 gallons so i dunno
  15. #15 Re: fuel tank capicity
    GTX Level Member webracin's Avatar
    Arkansas
    I have 2 GTP's, one is a 2000 and one a 2001.....
    The 2000 when on E will only take about 13 gallons of gas, but the 01 when on E will take 17.8 gallons.
    Sheryl and I tested out a theory on a road trip back from Florida when we bought the 00 GTP and this is what we found. Filled both cars up at the same time with Super Unleaded. Drove about 100 miles and the 01 needle was at about 7/8 of a tank. The 00 was at 3/4. Another 100 miles down the road, the 01 was at a 1/2 tank, and the 00 was at a little under a 1/4. At 250 highway miles, the 00 had both low fuel lights on, so we stopped and the 00 only took 12 gallons, and the 01 took 12.5 gallons (but the 01 fuel guage was reading over 1/4 tank).
    For some reason not all the fuel sending units are calibrated the same. We have found with the 00 that we can drive almost 100 miles when both low fuel lights come on, but on the 01 its only about 30.
    Try this at your own risk, and I would recommend having a gas can in the trunk just in case, but I think its your sender that is not reading a TRUE empty tank
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  16. #16 Re: fuel tank capicity
    Apr 2008
    Interesring. Good info Web. Thanks for sharing.
  17. #17 Re: fuel tank capicity
    Jan 2009
    Daytona Beach, FL
    I have experienced with not only mine, but two of my friends have also noticed that on the 2001 GT's, the fuel gague can be quite a deciever. with my car, the most I've ever filled up was 18 gallons even, and I was driving it down the highway, didnt realize I was BELOW E, and rolled into the gas station at about 5 miles an hour with 0 gas and the engine off. Lucky me, eh? Anyways, for about 3 gallons after you start the car again, the call will remain on Full. It goes down normally after that. But, it gets to E when it has about 3 gallons left, so I guestimate how much more driving I have after that. However, this is on MY car, mine just might be slightly on the stranger side of things, so I don't reccomend running out of gas based on my calculations. I have found however, that my computer for the gas used, is extremely accurate so I use this in replace for watching my fuel gague. I don't know if all 2001's have the computer with the - Oil life %, Range, Gas used, and mpg - feature on the dash, but if yours has it I'm sure it works as good as mine does
    Just figure I'd throw that little thing with the Empty and Full false readings out there for other people...
  18. #18 Re: fuel tank capicity
    Moore,OK
    well, i looked all around and can't figure this out. it's definitely not a sending unit problem. i usually drive till i can hear the fuel pump cavitating at stoplights and then i'll go fill it up. the most it holds is 12 gal. the only thing i can think of is this car has had some damage underneath (looks like it went over a big curb sideways) and someone replaced the tank with one from a 4cyl. grand am(?) i dunno....
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  19. #19 Re: fuel tank capicity
    Dec 2008
    Canada
    Quote Originally Posted by Forrest View Post
    OFF TOPIC -Just like to point out this guy is from from FL and he said EH! Meaning it isn't only Canadians that say it I make it a habit to read all posts in the thread and this time it has paid off Boy if he is a Canadian who left for warmer weather this is going to bit me in the ass lol
  20. #20 Re: fuel tank capicity
    Jan 2009
    Daytona Beach, FL
    Quote Originally Posted by 1998xGTP View Post
    lol born and raised in Florida, But I do have a good friend from Australia who then moved to canada, who then moved down here :P So I may have picked it up there lol
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
