Thread: power seat issue
Results 1 to 4 of 4
  1. #1 power seat issue
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I was cleaning under the seats in the GTP, i moved the drive seat all the way forward. when i went to move it back only one side moved.
    It looks like the metal cable connecting the two tracks came out. I tried just shoving it back in but clip for the carrier tube is in the way.
    does anyone know how to remove it, i fiddled with it, but its tight space and i have large hands.
  2. #2 Re: power seat issue
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    if nobody answers your best bet may be to remove the seat, especially since the really ins't much room to work with under there. I'm sure the cable is the issue... just a matter of being able to hook it back up lol
  3. #3 Re: power seat issue
    Oct 2011
    Toledo, OH
    Something is probably stuck in the track. If it's an 04+ there is only one ball screw that moves the seat forward and back.
    7"
  4. #4 Re: power seat issue
    Since it's forward.. you can undo the two 15mm bolts at the back holding the seat in. Lean the seat forward and disengage the hooks. Then with the seat out.. you can see better and maybe fix it.
    Silly manual GP seats
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. heated seat issue
    By jhintz in forum General Tech Discussion
    Last Post: 09-18-2012, 03:27 PM
  3. heated seat issue
    By jhintz in forum Introductions/Noob Questions
  4. power seat issue
    By kymtnman in forum General Grand Prix Discussion
    Last Post: 08-20-2012, 12:33 PM
  5. Seat warmer issue
    By JSauter816 in forum General Tech Discussion
    Last Post: 05-02-2010, 06:41 PM
