Thread: fukkin cylinder 5
Results 1 to 19 of 19
  1. #1 fukkin cylinder 5
    Joliet, IL
    ok i keep misfiring on cylinder 5 and the plug cracks every time i scanned from a 30 roll and the aero says cyl 5 misfired 22 times.....thinkin about moving coils around to see if the misfire follows the coil ....hmmm this cant be a sign of internal problems can it?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: fukkin cylinder 5
    Banned - Busted For Scamming
    Feb 2009
    Pics of said plug. Detonation could cause it though maybe cracking the plug.
  3. #3 Re: fukkin cylinder 5
    Plug damage most of the time means there is something flying around in there causing that...as in...a piece of a piston.
  4. #4 Re: fukkin cylinder 5
    May 2008
    McHenry IL
    welcome to my world my cylinder 5 is what is the problem... =[
  5. #5 Re: fukkin cylinder 5
    Joliet, IL
    ill get pics up if i can....i hope its not an internal issue ill be pissed....
    00 Silvermist GTP
  6. #6 Re: fukkin cylinder 5
    yeah, usually screwed up plugs mean something is in there bouncing around. if its a piece of piston i bet i can bet where on the piston it chipped off.
  7. #7 Re: fukkin cylinder 5
    Bastard Reptile's Avatar
    Kansas City, MO
    1-2 O'Clock area would be my guess.
  8. #8 Re: fukkin cylinder 5
    May 2008
    McHenry IL
    be prepared to become pissed......
  9. #9 Re: fukkin cylinder 5
    Charles City, IA
    Just buy a short block and be happy
    SMGPFC Two Nipple General
  10. #10 Re: fukkin cylinder 5
  11. #11 Re: fukkin cylinder 5
    May 2008
    McHenry IL
    no good
  12. #12 Re: fukkin cylinder 5
    Joliet, IL
    ok guys now the misfire has moved to 3,4,5 and the plug wasnt cracked my mistake i thought i saw hairline cracks on it last night but i was dark....no cracks just random misfires all over im gonna have to go with i need colder plugs or new wires/coils....
    00 Silvermist GTP
  13. #13 Re: fukkin cylinder 5
  14. #14 Re: fukkin cylinder 5
    Joliet, IL
    whats your plug gap look like?
    i set them at .55 but ill check to see if it has moved (like its been hit) *sigh*
    00 Silvermist GTP
  15. #15 Re: fukkin cylinder 5
    Jan 1970
    Maquoketa, Iowa
    Switch to AL104's and gap around .05. This only happens after you see boost or does it happen at idle also?
  16. #16 Re: fukkin cylinder 5
    Guam
    Run the stock plugs...
  17. #17 Re: fukkin cylinder 5
    Joliet, IL
    when im boosting is the only time it happens....it did this intermittently with 104's however also....but i did have a cracked plug....i did another scan today and cylinders 4,5 and 5 misfired cyl5 3 times and cyl4 1......this was at WOT.....but sometimes ill do the same 3mph pull with no misfires....
    00 Silvermist GTP
  18. #18 Re: fukkin cylinder 5
    its funny since my car misfired at idle since i had it together, but it never misfired at WOT unless i was running retarded lean/rich.
  19. #19 Re: fukkin cylinder 5
    Guam
    What kind of code reader are you using? Any codes coming up?
    You can determine which clylinder it is using a Tech 2 for example. It will give you misfire history and will show you what cylinder is creating the condition.
    I would say your next course of action after replacing the spark plugs, is to obtain a correect data list to determine what cylinder is misfiring.
  1. 5 Cylinder GTP
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 10:42 AM
  2. cylinder heads
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:48 PM
  3. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  4. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
