Thread: Gasket Help
Results 1 to 4 of 4
  1. #1 Gasket Help
    Sep 2014
    United States
    Can anyone tell me if RTV goes on gasket 1, 2, or 3? Also the number 3 gasket is for the oil pick tube but what are the o-rings for in the bag. I think the smaller one is for dip stick. The other 2 I have not seen anywhere on the engine.
  2. #2 Re: Gasket Help
    HUDSON
    The paper gaskets do not need RTV, just make sure the metal surfaces are perfectly clean. The small o-ring does look like for the Oil dipstick, the large one maybe for the mass air flow sensor, the other ones I don't know about, someone else may.
  3. #3 Re: Gasket Help
    Sep 2014
    United States
    Thanks for the response! I have replace most all of my other gaskets. the project is starting to come back together.
  4. #4 Re: Gasket Help
    On the rear engine cover gasket. I always use a light amount of RTV on both sides of the bottom 1.5". That is a common leak area. Also I'd suggest a little loctite on it's bolts. They like to loosen.
    Everything else.. no RTV.
    The smallest o-ring is for the dipstick tube seal.
    Large o-ring, I forget, however IIRC it's too big to be a coolant o-ring
    The flat ring is for the oil pan drain plug on the aluminum pan motor.
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
