Thread: Alternator Whine when car off.
Results 1 to 19 of 19
  1. #1 Alternator Whine when car off.
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    EDIT: Solved - see post dated Nov 14, 2014.
    Hi guys,
    Car: 2000 GTP
    So something has been killing my battery when I let it sit overnight, and I think its my alternator.
    When I turn the car off with the battery connected, I get a periodic low electrical hum/whine from the alternator. This noise sequence is thus: low hum for 2 seconds then off for 2 seconds, then hum again for 2 seconds then stops, etc.
    Any idea on if/how I can test this? Read somewhere that the 'field' part of the alternator might still be powered once the car is turned off, and this could be causing the battery drain, but I'm nor well versed enough with electrical knowledge to test this.
    Thanks.
    PS. Mods, if this is the wrong section, let me know and I'll move it.
  2. #2 Re: Alternator Whine when car off.
    drive a parts store, have the alt and battery tested.
    if you have avolt meter, car off test the batery, you want to see 12 volts at least.
    car on test the battery again, you want to see over 13 volts now, up to 14.
  3. #3 Re: Alternator Whine when car off.
    GT Level Member blownGP's Avatar
    Sep 2013
    Iowa
    Unhook the alternator overnight and see what happens if the battery doesn't drain there's your problem. Using a volt meter to test battery voltage won't really tell you anything beside if you sit there and watch it for a couple of hours you might be able to watch it drain. You could use the voltmeter to check and see if anything is pulling any unreasonable voltage while the car is off by testing wires individually
    2000 2500 Chevy with 6 inch lift build thread- http://www.gmt400.com/forum/showthre...d-Crew-Cab-454 2006 Grand Prix supercharged build thread- http://www.grandprixforums.net/blown...ead-82585.html
  4. #4 Re: Alternator Whine when car off.
    Dec 2008
    Scottydoggs: checked the battery and alt - they check out ok per your criteria. 12.7v on the battery when car off, and 13.4 or something with the car running. Alternator bench tested ok too.
    Blowngp: to unhook the alternator, do I just remove the two-wire harness? Its a 4 pin plug but only 2 wires go into it. Or should I remove all the alternator plugs/wires like the big red one too?
    Thanks to both of you for your help. I'm hoping I can sort this sucker out. It was working fine and I've followed some other instructions regarding testing for other sources of current draw but can't find anything else. I only heard this alternator noise by chance and it stopped once I disconnected the battery.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  5. #5 Re: Alternator Whine when car off.
    taking that thick cable off the alt, and un plugging the flat plug should do it.
    edit: the alt could have a bad voltage regulator. unplugging it will test that. if its good int he moring the alt is bad.
  6. #6 Re: Alternator Whine when car off.
    Dec 2008
    Good man!
    Right then that's what I'll do. I'll update this thread in the morning.
    Cheers mate!
  7. #7 Re: Alternator Whine when car off.
    Dec 2008
    OK so I unhooked the alternator as suggested, and I'll check tomorrow.
    One thing I wanted to talk about was then when I re-connected the battery, I checked the voltage going to the alternator plug.
    Pin B was receiving 12+v on it once the battery was connected.
    I don't know if that's normal or not, and maybe that's why my alternator is receiving power and making the noise too?
    If anyone has a clue whether this is supposed to be powered once the battery is connected, pop in .
  8. #8 Re: Alternator Whine when car off.
    no clue on the diagram.
    but ive got the same issue im dealing with on a commercial lawn mower, battery dies over night. was told by the starter and alt re builder to unplug the voltage regulator when it sits over night. if the battery is still charged in the morning the v/r is bad.
    i just got it all back together the other day with a fresh charge, everything hooked up, the battery was dead 2 days later, so i need to charge and unplug the v/r to see if thats my parasitic draw.
  9. #9 Re: Alternator Whine when car off.
    Dec 2008
    UPDATE:
    Scotty/blowngp: So I started it up my car this morning and it starts up fine. So it definitely looks like the alternator/voltage regulator is kaput.
    I don't know if there's a way to replace only the voltage regulator, but I guess I'll pull it off and have a look. Thanks for all your help with this guys!
    Scotty, Good luck with the lawnmower. Hope you find it to be a cheap and easy fix!
  10. #10 Re: Alternator Whine when car off.
    Sep 2013
    Iowa
    Have you tested the battery?
  11. #11 Re: Alternator Whine when car off.
    Dec 2008
    Yeah battery was holding at the same voltage as last night - 12.46v.
    Edit: until I started it on battery and turned it off after 29 seconds - then it bacame 12.22v.
  12. #12 Re: Alternator Whine when car off.
    Sep 2013
    Iowa
    Quote Originally Posted by Panzer4 View Post
    That seems normal
  13. #13 Re: Alternator Whine when car off.
    Dec 2008
    So we both agree its the alternator then?
    edit: voltage regulator in the alternator?
  14. #14 Re: Alternator Whine when car off.
    Sep 2013
    Iowa
    That'd be what I'd try
  15. #15 Re: Alternator Whine when car off.
    Only way to replace parts in it is to bring it to a alt/starter shop or learn how on your own. I'd bring it to a shop.
  16. #16 Re: Alternator Whine when car off.
    i looked into rebuilding my own alt, the rebuild kit is like 35 bucks. but, you need a press to to even get close to working on it. no press to use, take it to a re builder. cause you'll never open it all up.
  17. #17 Re: Alternator Whine when car off.
    Dec 2008
    I'm taking it to a good alternator shop tomorrow. I was doing some reading about how a bad diode can cause a parasitic drain.
    Will update you guys once I find out. This has been one of the most curious problems I've had with this car!
  18. #18 Re: Alternator Whine when car off.
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Hm. That is neat. I'd just throw a JY alt in lol
    04 GTP -HAI, 1.9 rockers.
  19. #19 Re: Alternator Whine when car off.
    Dec 2008
    SOLVED:
    OK so after weeks of messing about, getting the alternator checked and rechecked, nothing seemed to work.
    There was a bad diode, which I got replaced, but I was still dogged by the same problem.
    Then I fliiped open my downloaded copy of the tech manual (thank you torrents) and discovered that the wires for the voltage regulator connector were switched somehow.
    Simply switching them over has solved my problem.
    Of the two wires in that connector, one is the alt sense, which is always hot, and the other is the reference voltage wire for the regulator, which turns off when the car is off. With the wires being switched, the reference voltage pin was always hot, and that caused the slight whine/him from the alt, as well as draining the battery.
    Thank you all for your help.
  1. No whine
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2013, 03:01 PM
  2. Whine
    By 2coolit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2013, 09:39 PM
  3. Alternator whine in my speakers
    By Wakeboy1337 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2011, 04:28 AM
  4. My car has a whine, and it's N/A?
    By JESSEGOTTA GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2010, 04:09 AM
  5. whine
    By Starick58 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2008, 01:55 PM
