Thread: plugs for 3.4
Results 1 to 20 of 29
  1. #1 plugs for 3.4
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    So I'm planning on doing a 3.4 pulley and header setup next week. I want to make sure which plugs I should be getting. There seems to be some differing information depending on where I look, some places say get tr6s and some say tr55s, so I'm not sure which I should get. Just want to be sure I'm getting the correct plugs
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  2. #2 plugs for 3.4
    Copper ftw.. I'd stick to autolite 606s
    04 Comp G.
  3. #3 Re: plugs for 3.4
    Guess what, this thread will be no different after 10 posts from those other threads or places of infomation.
    There will be 3 guys saying 1 thing, 4 guys saying another and so on.
    You always want to run the hottest plug you can get away with, plan and simple. So figure anything from a 605 plug to a 104 if it really needs it. Spend 20 bucks and buy 12 plugs and run 1 set and look them over after a few pulls. If they look decent or look bad swap them and do the same thing again. The motor will tell you whats gong on.
    I went with autolites in my little rant here, but you can figure out what those heat ranges are for NGK yourself.
  4. #4 Re: plugs for 3.4
    104 coppers in my 3.4 set up.
  5. #5 Re: plugs for 3.4
    The Boss Iceman6669's Avatar
    Jun 2011
    Al 104 coppers for my 3.4" setup
    2011 F-150 Yote powered
  6. #6 Re: plugs for 3.4
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I have found 605's sufficient for the whole 3.8-3.4 range of pullies. Changing from 605's to 104's did not allow me to run any more timing or leaner AFR on a 3.4 ... I don't know of any evidence that colder plugs make a difference at this mod level.
    The general consensus to to run 104's, however.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: plugs for 3.4
    May 2012
    Where winter never ends
    I ran 104s down to a 2.8... 103 on my turbo setup, back up to 104s.. car likes 104s much better than 03s
    2000 Regal - Winter Beater
  8. #8 Re: plugs for 3.4
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by adecker View Post
    What issues did you have with the 103s? any? I was about to swap from 104s to 103s this week on my 3.1" M90 pulley setup...
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  9. #9 Re: plugs for 3.4
    Run 605. I run 104 on my 2.8 setup
  10. #10 Re: plugs for 3.4
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    I just ordered tr6's but motor is still apart, wont be dropping any pulley sizes till I get an aeroforce scan gauge
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  11. #11 Re: plugs for 3.4
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I currently run autolight 104s but ngk tr6 plugs and ngk tr55 plugs both seem to give a better idle quality on my friends cars so ill be running them on my next plug change.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  12. #12 Re: plugs for 3.4
    Dec 2013
    maine
    Thanks for the input. Probably going to go with TR6s, which are equivalent to AL104s from what I've read, as that seems to be what most are running
  13. #13 Re: plugs for 3.4
    I just always stuck with AL's because they're cheaper and they work just as good.
    TR6's honestly are too cold for a 3.4" setup.
    I'd run 605's gapped at .050" and never look back.
    If you're knocking, I'd look elsewhere...as plugs won't fix a knock issue unless they needed replaced.
  14. #14 Re: plugs for 3.4
    Jun 2011
    I've been thinking about trying 103s in mine. Just to see how they look.
  15. #15 Re: plugs for 3.4
    Josh run 605's like you should
  16. #16 Re: plugs for 3.4
    Jun 2011
    My 104s look boarder line too hot.
  17. #17 Re: plugs for 3.4
    Quote Originally Posted by Iceman6669 View Post
    They aren't I can guarantee you can run 605's just fine.
  18. #18 Re: plugs for 3.4
    Jun 2011
    Uh. I think otherwise.
  19. #19 Re: plugs for 3.4
    Try it I guarantee you don't notice a difference
  20. #20 Re: plugs for 3.4
    May 2012
    103s worked but it seems to like 104s better
  1. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. NGK TR6 plugs
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2010, 01:36 PM
  4. what plugs to buy?
    By vailskier3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 09:20 AM
  5. TRI-55X Plugs=bad KR for my car?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2008, 04:44 PM
