Thread: Fuel
Results 1 to 20 of 36
  1. #1 Fuel
    Mar 2013
    Norfolk va
    Hey guys, I'm just wondering what gas is the best gas for our cars, other than e85 because I don't think its available in my area..
    Sent from my SCH-I535 using Tapatalk
  2. #2 Re: Fuel
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    As high of octane as you can get!! If you really want to know if you have E85, get one of the free "Ethanol Locator" apps for smart phones. Mine picks up a lot of additional E85 stations that I had never found or knew of before in my area.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: Fuel
    Without knowing what you drive I can't say.
    A L36/L26 motor only needs 87 to run normal. A L67/L32 needs 91+ because it has a supercharger.
    If going for all out performance and it's ability to reduce knock for pump gas, find 93 or 94 octane gas.
    E85 is another topic that I don't care to talk about.
  4. #4 Re: Fuel
    Mar 2013
    Norfolk va
    Sorry I haven't used this app allot and am still learning it. I will try and update mods in SIG.. I have a 2003 l67.. Cam intake, header back exhaust. Ported throttle body..
  5. #5 Re: Fuel
    Mar 2013
    Norfolk va
    Oh and a canned tune.. I was getting 7 degrees of knock. I was on the same plugs for like three years.. So I did a tune up with iridium's NGK tr6 wires and coils.. Part throttle and half throttle are so much better now , but full throttle still is showing 7 degrees of knock.. Oh and I'm on a 3.4 pulley..
  6. #6 Re: Fuel
    I'd pulley up if you see that much at WOT with running 91+ fuel.
    Either it's real knock or something is rubbing the exhaust to make it think knock is going on.
  7. #7 Re: Fuel
    Mar 2013
    Norfolk va
    I've been told that with my mods , I should easily be running a3.4.. When I goe the can and supporting mods, I got a canned dhp pcm.. Could it be that the tune sucks?
  8. #8 Re: Fuel
    Mar 2014
    Cincinnati, OH
    Do you have HPTuners? If so, I can aend you my email so you can send me your tune file and I can pull it up and take a look. Could be the tune. Depending on what cam you have, a 3.4 should easily be within reach, if not smaller with no KR. Something seems odd about that with your setup.
    2002 GTP sedan:
  9. #9 Re: Fuel
    Mar 2013
    Norfolk va
    Sadly I don't have hptuners ..I forget the specs bit its the only cam robert at 3800 performance for the l67
  10. #10 Re: Fuel
    http://www.e85prices.com/virginia.html
    Well considering E85 IS available this decision is easy...........
  11. #11 Re: Fuel
    Mar 2013
    Norfolk va
    Yea I downloaded the app as you suggested..only places in Norfolk are on the military bases, and I'm not in the military.. There's one in va beach and not close enough, and one other in Newport News..
  12. #12 Re: Fuel
    Mar 2013
    Norfolk va
    And those locations are like hours away..
  13. #13 Re: Fuel
    Airport BP? that one has it. Im in DC and I only have one station here out in BFE on Wisconsin ave. However even only having one to deal with it STILL completely worth it.
  14. #14 Re: Fuel
    Mar 2013
    Norfolk va
    Yea airport bp is a good half-hour away when traffic is good.. B3ing that I have to cross a bridge- tunnel to get there I dunno.. I appreciate the effort you guys have put into helping me.. Do u tune by chance 98 chain?
  15. #15 Re: Fuel
    St. Louis
    Could always find some Sunoco Blue
  16. #16 Re: Fuel
    Mar 2013
    Norfolk va
    Race fuel?
  17. #17 Re: Fuel
    Quote Originally Posted by grazin View Post
    Have an HPT tuner here in DC with me yes im pretty sure I could do a few mild things, but by no means claim to be a tuner.
    And for the E85... Meh gave it a shot. Best off use 93 then and a solid tune.
  18. #18 Re: Fuel
    Nov 2011
    NY
    Race fuel?
    Try Torco additives then, or have a 55 gal drum of ethanol dropped at your door and make your own mix... There's always a way if you want it bad enough. Hell, you could even MAKE your own ethanol, being from Virginia, I'm sure there's some people down there with the knowledge
    Lastly, 7* of knock is ok on stock, but with a smaller pulley you're pushing things, better save up for an engine swap, just sayin!
  19. #19 Re: Fuel
    Mar 2013
    Norfolk va
    Thanks for all the input guys.. I just got a p0420 code so I think I'm going to replace both o2 sensors as they are original equipment, and then probably take it to Virginia speed for a complete tune.. They tune allot of ls cars, so I'm hoping they can do something for me..
  20. #20 Re: Fuel
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Quote Originally Posted by FordMan77 View Post
    The Sunoco near me has "racing fuel" but it says 90 octane?
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
