Thread: Heavy Isolated Misfire Under Load
Page 10 of 10 FirstFirst ... 8910
Results 181 to 197 of 197
  1. #181 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    We thought the initial issue was a bent valve due to the missing rocker pedestal.
    No case learn its a 97.
  2. #182 Re: Heavy Isolated Misfire Under Load
    You can case a 97.
    PCM knowing TDC is the pcm knowing TDC. It's an optimization. Just because the KM is removable doesn't mean it can't benefit from a learn.
  3. #183 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    How do I do a case learn then? Is it the same as other years?
    When ever I tried it on the aero force I didn't think it worked.
  4. #184 Re: Heavy Isolated Misfire Under Load
    Yeah..same as all years.. get up to temp.. tell it to do it.. rev to limiter and poof..
    Reason why I suggest it is you seem to have ruled out almost everything. When you did the rockers.. one thing you should have done is turn the motor with ignition off to retorque the rockers. I have seen a few cars that ran like poo after a swap etc. Not many..but a few. No real info.. no real codes.. nothing seemingly out of whack. I case learned and it was magic. So the assumption would be that the pcm didn't have a good bearing on where TDC was ...even though there's a few different ways it determines it.
  5. #185 Re: Heavy Isolated Misfire Under Load
    http://www.grandprix.net/forum/ubbth...t&Number=92035
    Regardless what they say in the thread about 97...I'd do what Bill says.
  6. #186 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I'll try it.
    Do I get any kind of confirmation that it did the case relearn?
  7. #187 Re: Heavy Isolated Misfire Under Load
    Depends.. I do with HPT.
  8. #188 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I'll try it again. But I don't think its working.
  9. #189 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Joe, I don't remember but are you S/C or N/A?
  10. #190 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    S/c
  11. #191 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Alright just wanted to know cause if, worst case scenario, you need a camshaft and choose to stay with a stock one, I'll sell you mine cheap
  12. #192 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    No way in hell another stock cam is going in if that's it.
  13. #193 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by Jomamma View Post
    Lol IK I wouldn't put another stock cam in either but just in case you wanted stock
  14. #194 Re: Heavy Isolated Misfire Under Load
    Sell a stock cam.... Kyle.. you should be ashamed of yourself.
  15. #195 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Nope.
  16. #196 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    So is the misfire fixed?
  17. #197 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Nope. I've been real busy... And it's cold
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
