Thread: With my 3.1 pulley, what spark plugs to run?
Results 1 to 16 of 16
  1. #1 With my 3.1 pulley, what spark plugs to run?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I am currently running AL104s. With my 3.1 pulley, should I drop to 103s?
    I see small blips of knock here and there but it may be due to being slightly rich at times. Still playing with fuel tables a bit and dialing it in after my latest mods (rockers and pulley swap)
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: With my 3.1 pulley, what spark plugs to run?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    I would go to 103s. I've had good luck with them even on bigger pulley setups.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: With my 3.1 pulley, what spark plugs to run?
    GrandPrix Junkie
    Mar 2012
    NC
    I vote stock. Has anyone ever officially proven colder plugs are 100% necessary with a proper tune?
  4. #4 Re: With my 3.1 pulley, what spark plugs to run?
    gardner,mass
    So true isnt v6 running 606s on his twin engine car....
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: With my 3.1 pulley, what spark plugs to run?
    The Boss Iceman6669's Avatar
    Jun 2011
    I say 103s. Depending on how the 104s look.
    2011 F-150 Yote powered
  6. #6 Re: With my 3.1 pulley, what spark plugs to run?
    Aug 2013
    Sandy, UT
    ... I guess not? But what can it hurt... right?
  7. #7 Re: With my 3.1 pulley, what spark plugs to run?
    Aug 2013
    Sandy, UT
    Quote Originally Posted by SnowTh1ef View Post
    How can how the plugs look tell you what direction to go with your plugs? Just wondering because I have never heard that before
  8. #8 Re: With my 3.1 pulley, what spark plugs to run?
    Jun 2011
    It can indicate the temp. If they are nice and white is nice and lean. Golden is a good range, dark Brown or blackish will be too rich. Too rich indicates you should go a little warmer. Too Lean would be a little cooler.
  9. #9 Re: With my 3.1 pulley, what spark plugs to run?
    GrandPrix Junkie
    Mar 2012
    NC
    Quote Originally Posted by Iceman6669 View Post
    It can indicate the temp. If they are nice and white is nice and lean. Golden is a good range, dark Brown or blackish will be too rich. Too rich indicates you COULD go a little warmer. Too Lean COULD be a little cooler. Obviously this is dependent on a proper tune.
    Edited before the tuner guys get here. LOL
  10. #10 Re: With my 3.1 pulley, what spark plugs to run?
    Jun 2011
    Good looking out.
  11. #11 Re: With my 3.1 pulley, what spark plugs to run?
    Aug 2013
    Sandy, UT
    Ah ok. I knew the dark was rich and light was lean Just didn't know how that applied to temps. Good to know!
  12. #12 Re: With my 3.1 pulley, what spark plugs to run?
    I'd run 104's
  13. #13 Re: With my 3.1 pulley, what spark plugs to run?
    Oct 2011
    Puyallup WA
    I run 605's no issues
    08 G8 GT - exhaust Tune
  14. #14 Re: With my 3.1 pulley, what spark plugs to run?
    It's the hottest spark you can get away with, no the coldest.
    I just run cold plugs with a small gap because I'm lazy AF.
  15. #15 Re: With my 3.1 pulley, what spark plugs to run?
    Mar 2014
    Cincinnati, OH
    Sounds like I should maybe stick with my 104s for now and just monitor knock. If I continue to see blips here and there maybe I'll give 103s a shot to see if it takes care of it
    2002 GTP sedan:
  16. #16 Re: With my 3.1 pulley, what spark plugs to run?
    Donating Users Uno99's Avatar
    Appleton, Wi
    Great info.... right now with the VS cam, tune @ 18* timing they are that grayish color. I'll swap the 3.4 on throw in the 104 ' s and take the timing back down and slowly work it back up then read the plugs again. I keep saying the 3.4 is enough for my DD but I keep looking for a 3.2 to come up for sale. It never ends.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  1. Has any one used E3 spark plugs on 04+ GTP
    By daltman360 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2013, 09:16 AM
  2. Spark plugs?
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2013, 06:26 PM
  3. which spark plugs is everyone using?
    By ls1racer11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2013, 02:30 AM
  4. 06 GP 3.8 looking for spark plugs
    By chas300x6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2012, 02:13 PM
  5. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
