Thread: Meziere Water Pump....... need help
Results 1 to 6 of 6
  1. #1 Meziere Water Pump....... need help
    Jun 2012
    Cold Spring, MN
    I have a Meziere's EWP on my Monte Carlo and am having problems with it overheating after the car has run for 3-4 minutes.
    I replaced the radiator because I thought I could hear the water pump running, but first start up after replacing the radiator and bleeding the cooling system it's already overheating.
    For those of you with a Meziere's EWP, how loud is yours with the key on/engine off/water pump running?
  2. #2 Re: Meziere Water Pump....... need help
    only way i see it over heating from ice cold to over heating in 3 to 4 minutes is if theres no coolant in the block.
    if you take the t stat housing off remove the t stat, then put the housing back on and remove the hose from the rad, then turn the pump on, out the upper hose will flow coolant out it if the pump is working.
  3. #3 Re: Meziere Water Pump....... need help
    Jun 2012
    Cold Spring, MN
    We filled the block through the t-stat housing after the radiator was installed/filled.
    We also tested the t-stat and it is working great (also have extra holes drilled around the edge).
    It was probably more than 3-4 mins but it started overheating while we were trying to bleed the system.
    As soon as the temp guage starts moving it keeps on going until we shut the engine off.
  4. #4 Re: Meziere Water Pump....... need help
    is the pump pumping tho? it might be super weak if you cant hear it as loud as you used to.
  5. #5 Re: Meziere Water Pump....... need help
    Quincy, Mass
    You sure the temp sensor isn't bad or the wiring going to it?
    No more GP 04 Impala SS Indy:
  6. #6 Re: Meziere Water Pump....... need help
    Jun 2012
    Cold Spring, MN
    Turns out there was a weak contact inside the pump -sending the pump back to Meziere's to get warrantied out.
    Thanks for the input guys.
  1. Meziere pump + 4" shorter belt??
    By Beans455 in forum General Tech Discussion
    Last Post: 05-18-2016, 11:28 AM
  2. red anodize Meziere Enterprises Electric Water Pump
    By Spartan GL in forum For Sale - Parts
    Last Post: 06-19-2015, 06:31 PM
  3. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  4. electric water pump (meziere)
    By gtp38oo in forum General Tech Discussion
    Last Post: 06-30-2012, 04:33 PM
  5. Replies: 1
    Last Post: 04-02-2012, 05:20 PM
