Thread: P0102 code and no MAF readings on the aeroforce
Results 1 to 14 of 14
  1. #1 P0102 code and no MAF readings on the aeroforce
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Today, CEL came on. Pulled the code and I'm seeing P0102 (MAF issue). Checked the aeroforce gauge and sure enough, no frequencies showing up from the MAF. checked the MAF connections and everything looks fine.
    what to check next?!
    okay to drive it like this for a bit?? I'll stay out of boost in the meantime
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: P0102 code and no MAF readings on the aeroforce
    fuse box, # 26 iirc check it, see if its blown.
  3. #3 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    Will do. You da man Scotty
    2002 GTP sedan:
  4. #4 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    Fixed it! Blown fuse. Fuse #21 (15 Amp) for anyone else in need.
    2002 GTP sedan:
  5. #5 Re: P0102 code and no MAF readings on the aeroforce
    21, 26, i was close right lol.
    good to hear.
  6. #6 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    good to hear.
    Haha.. Don't worry, that "you da man" statement still applies. You led me right to the solution
    2002 GTP sedan:
  7. #7 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    Well.. Fuse blew again.. Anyone know what might be causing this?? Something is up as the fuse has blown twice within 24 hours.
    thanks for any advice
    2002 GTP sedan:
  8. #8 Re: P0102 code and no MAF readings on the aeroforce
    bad wires to the maf, or the up stream o2, that fuse its for both of those.
  9. #9 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    Hmm. Okay, wonder how I do some testing on those..
    2002 GTP sedan:
  10. #10 Re: P0102 code and no MAF readings on the aeroforce
    your eyes work well to start with.
    look at the plug ends for cracks or missing insulation, and down the wires too. if you can see bare wire, that pig tail is bad. or if you find the wires melted to the engine, theres a clue too.
    check the maf and the o2 wires.
  11. #11 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    Think I may have found a potential root cause. Just ran out on while at lunch and check some wires. I recently removed my boost solenoid setup (and trimmed wires back in the process). Looked like there was some exposed wire there they could have touched each other. According to the handbook that came with the car, fuse 21 can be associated with the boost solenoid as well. So, going to switch out the fuse again and see if that fixes it.
    Thanks again Scotty
    2002 GTP sedan:
  12. #12 Re: P0102 code and no MAF readings on the aeroforce
    you got, good luck.
    with that info looking at what you last touched is a clue.
  13. #13 Re: P0102 code and no MAF readings on the aeroforce
    Mar 2014
    Cincinnati, OH
    agreed. I'll clean up those wires and swap fuses again and see if the issue stays away.
    I owe you a beer. let me know if you are swingin through cincinnati anytime soon
    2002 GTP sedan:
  14. #14 Re: P0102 code and no MAF readings on the aeroforce
    this could be a easy fix, no worry's a bout the beers lol
  1. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  2. MAF P0102 Code
    By gp99 in forum Introductions/Noob Questions
    Last Post: 08-27-2013, 01:08 PM
  3. p0102 code help
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2012, 06:47 PM
  4. Code P0102
    By PCTGTP in forum General Tech Discussion
    Last Post: 08-16-2009, 09:35 AM
  5. code P0102
    Last Post: 08-02-2009, 01:43 PM
