Thread: Need Help with short!!!???
Results 1 to 3 of 3
  1. #1 Need Help with short!!!???
    SE Level Member TuKoolGTP's Avatar
    Nanamo, BC, Canada
    I replaced the oil pan this week end. Committed a cardinal sin and did not disconnect the negative terminal of the battery before lifting the engine. Part way into the lift something shorted. Seemed to be in the area under the throttle body above the transmission. Car started fine and everything seemed to be OK. Now realized the battery is not charging and car went dead.
    I pulled the air box out to try and see where it happened, but can't see anything.
    Any suggestion where to look? What to try?
    1998 GTP
    Custom CAI | PowrTuner | AL 104s | TBS | 3" DP | Res Del | 180 TS | 3.6 | PEM
  2. #2 Re: Need Help with short!!!???
    Nanamo, BC, Canada
    It was the fusable link at the starter going to the alternator.
  3. #3 Re: Need Help with short!!!???
    Nanamo, BC, Canada
    Having trouble locating a 10 Awg fusible link in Nanaimo BC. Anyone know of a place?
  1. looking for a short stack I/C
    By StandAloneCustoms in forum Wanted To Buy - Parts
    Last Post: 11-26-2013, 02:24 AM
  2. Short block
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2012, 07:34 AM
  3. Short In Foglights
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 01-01-2012, 05:24 PM
  4. need a short block
    By Iwannagofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2011, 04:20 PM
  5. Altenator Short?? Help
    By GTP4EVER97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2011, 03:14 PM
