That makes sense
Sent from A Galaxy Far Far Away........
That makes sense
Yeah after measuring everything it doesn't seem like it would be much of a hp difference and I won't have to deal with the leaks and or issues that I have had with the headers...then if I actually do go turbo will be alot faster swap
Hmmmmm.. Now you're making me question whether or not I should switch lol
vette, if you decide not to switch I'll buy your headers :-)
or if you do.. I might buy your plog... I still cant decide. Bonnies don't have the restictive downpipe/ubend so idk if i even need a downpipe..
I'll let you know sometime this weekend bud. They come in the mail on Friday, and I am starting to wonder if I should take the time/effort to take off my whole setup as it sits just to put on these headers that may not gain me much. I will shoot you a PM Friday/Saturday time frame and let you know man!
If I could do it all over again I would have kept my plog and 3in dp honestly. I have had some issues even still nearly 6 months later after my header install, mainly exhaust leaks and this nagging front o2 sensor issue.
Yesh I'm in it about 2 years and from the get go my crossover never fit so always leaked a little at the front connection...I changed it to a v band connection last weekend and now the rear slip fit is leaking...my o2 has always hit from time to time and now all the welds are rusting...so since I didn't find a huge difference in primaries I'm swapping back
from what i understand, plog and DP combo is only good for ~300WHP. More than that and it becomes a restriction and headers are needed
i loved my speed daddy headers. they were super cheap and sealed just fine for me with no leaks...
Yeah some people don't have any issues other people have alot...I am part of the latter
Installed plog+dp and the power band is def more down low compared to the headers...did not switch the tune and I am getting no kr going to do some tuning push out the timing
Yeah it is prob me but after messing with those headers enough times I moved on...plus if I go turbo in the future this makes it faster to switch over
When I first installed my SD headers, I had leaks... I used the clamps that came with the kit. Threw those in the trash, bought the EZ seal band clamps, no more issues.
I had speed daddy set. Couldn't get to go on engine on the engine stand. Need the engine in the car so that I could pry harder.
Never installed.
I had ez clamps from day 1 crossover just never fit right...replaced slip fit in front with v band then rear slip fit started leaking...so I moved on
