Thread: 3800 SII main cap removal
Results 1 to 20 of 26
  1. #1 3800 SII main cap removal
    hangover park IL, in the garage working on one of 12 3800's
    a short vid of my puller...i'll post mmore pics later for those that want to undertake making their own... i may make a batch of 10 for those that dont have the tools to make their own...
    yes folks its just that easy...
  2. #2 Re: 3800 SII main cap removal
    Oklahoma
    If you do, hit me up. I may one day tear into my motor and that would come in handy.
  3. #3 Re: 3800 SII main cap removal
    Saraland Alabama
    very nice I may even be interested mostly due to the fact I'm too lazy to make my own
  4. #4 Re: 3800 SII main cap removal
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Thanks for posting that video.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: 3800 SII main cap removal
    Wichita, KS
    Great video, and great info.
    When I remove my main caps, the bearings are never going to be reused, so "massaging" them out with a plastic or rubber mallet is what I usually do. But your tool looks very useful regardless if the bearings are going to be used again or not. Seen many times, people e-ffing up their main caps or cranks by swinging the BFH at them.
    ~F~
  6. #6 Re: 3800 SII main cap removal
    Hoffman/Schaumburg, IL
    Yay ^^^ I was the camera-man..... seriously the tool works amazing, I wish we got the thrust bearing on tape that was cool
  7. #7 Re: 3800 SII main cap removal
    finally getting around to more detailed pics...
    3x1/2" redhead sleeved concrete anchor
    after modifications
    you can see the 3.550 c2c 1/2in holes and the center hole tapped to 1/2x13 for my K-D slide hammer (any of ya with pullers with anything other than 1/2 coarse thread?)
    alignment into cap
  8. #8 Re: 3800 SII main cap removal
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    the only other acceptable than this is a 2x4 wrapped with a rag and slid through the bores to whack against the crank counterweights.
    this is many times faster though
    on a side note... i've pulled spun bearing mains and had them mic to spec... the riv is getting its OE bearings reinstalled except for the cam...since they will be destroyed when the block get drilled #2&3 mains and a step drilled main galley
    hey dave good job with the cammera...if you have time stop by and i'll see what we can find with your car...
  9. #9 Re: 3800 SII main cap removal
    Saraland Alabama
    nice work
  10. #10 Re: 3800 SII main cap removal
    Oklahoma
    James, you are one innovative person. I would so love to come and spend a week with you and others on this board like Trannyman, Ron Vogel, Toasty, Reptile, UR LOSN, Farnsworth, and so many others that would take me forever to list. You guys just rock with your simple down home extremely effective solutions to things.
    Very impressive. If you ever get around to making these for sale, let me know. Oh, also, if you ever get around to digitizing your notebook for the WWW, let me know as well I would love to be a part of that.
  11. #11 Re: 3800 SII main cap removal
    wait till you see the final version of the rear balance shaft bearing plug and the oil pump priming tool i got in my head, only issue with this is that people will need to use the JP with its two pice crank gear to prime it without javing to pull it apart to put the crank gear on...
    a pressurized oil accumulator plumbed into the oil pres sending unit port can work just as well but i recognize that people may want a different method of priming the oil galleys
    majority of my time is taken up with work and the new fuel log jigs, but someday all my crap will be organized lol
  12. #12 Re: 3800 SII main cap removal
    Oklahoma
    I would love to learn to do all that you do. I would like to learn how to disassemble my engine and put it all back together, and work of course. Its something I have never done and I would like to do it one time, go through it, rebuild it using the best I can afford and just put it all back together.
  13. #13 Re: 3800 SII main cap removal
    Saraland Alabama
    just from some of the things you have spoken about I have no doubts you could rebuild your engine, it is extremely easy to do if you pay attention to details
  14. #14 Re: 3800 SII main cap removal
    quite true... measure thrice cut once... attention to detail and a good notebook for spec's clearances is alot of it....
  15. #15 Re: 3800 SII main cap removal
    Oklahoma
    Maybe, and I appreciate the vote of confidence. But stuff like that scares me, more so just because Ive never done it though. To say nothing that I probably dont have all the proper tools. But one of these days I hope to do so. If for no other reason than to just say I have.
  16. #16 Re: 3800 SII main cap removal
    Dec 2008
    Mission, TX
    where can you get the concrete anchor?
    where does it need to be clearanced, etc....could you post more details ??
    Thanks man its because I have been all excited about rebuilding my motor and Im having difficulty removing the main caps...had no idea they were pressed in lol...Got one off (#1) but cant get the others off...gonna try pounding on the crank with something(got a new one anyways)
  17. #17 Re: 3800 SII main cap removal
    Oklahoma
    Holy back from the dead post Batman.
  18. #18 Re: 3800 SII main cap removal
    Dec 2008
    Mission, TX
    Well I got the caps off with a mallet, a 2x4, a screwdriver, and a rag....but I would still like to know more info on this as Im sure I will tear it back down once I either 1. get a turbo on there and need to swap to lower compression pistons or 2. fry a piston or two with nitrous.
  19. #19 Re: 3800 SII main cap removal
    Dec 2008
    Mission, TX
    Sooo.where could I go for those concrete anchors?
    Would Home Depot have them?
  20. #20 Re: 3800 SII main cap removal
    I live here. UR LOSN's Avatar
    Rockford, IL
    yes they should!!!!!!
    Jey James... any luck on your oil priming thoughts???? I'm interested in those!!!!
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. Easy Dent Removal
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 04-04-2008, 05:17 PM
  3. Axle removal problems...please help!!
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 02:59 AM
  4. Valve Cover Removal
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 07:19 PM
  5. My 3800
    By Street Wolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 03:19 PM
