Thread: Exhaust bolt size
Results 1 to 5 of 5
SomeDudeAtHome Exhaust bolt size 08-21-2014, 09:32 PM
Scottydoggs Re: Exhaust bolt size 08-21-2014, 09:44 PM
SomeDudeAtHome Re: Exhaust bolt size 08-21-2014, 09:57 PM
Scottydoggs Re: Exhaust bolt size 08-22-2014, 12:09 AM
94GrandPrixSE Re: Exhaust bolt size 08-22-2014, 03:35 PM
  1. #1 Exhaust bolt size
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Can anyone tell me what size the exhaust bolts are? Length and their hardness or whatever they are suppose to be? My downpipe snapped today after the cat before the res and I'm going to have to replace it. Everything is so rusty I'm guessing I'm going to have to either cut the bolts or they'll break and want to be prepared. Don't want to be half way done and have to run to a store.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Exhaust bolt size
    ive been just grabbing a pair of 9/16 head bolts and nuts that are about a inch and 1/2 long, with 4 washers, one for each side for both bolts and nuts.
    the hole is pretty large.
  3. #3 Re: Exhaust bolt size
    Buffalo, NY
    Cool thanks I'll grab some of those in the next couple days. Do they need to be a certain strength or will any do?
  4. #4 Re: Exhaust bolt size
    ive been using the normal of the shelf bolts, they cost like a buck or two for everything. they all rust sooner or later.
  5. #5 Re: Exhaust bolt size
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I went with grade 8 bolts for not much more $.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  1. exhaust bolt size
    By DJNight2k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2013, 10:22 PM
  2. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  3. 97-03 GTP EGR tube bolt size?
    By AnotherGTP in forum General Tech Discussion
    Last Post: 01-25-2010, 11:27 PM
  4. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
  5. Exhaust bolt size
    By the1euge in forum General Tech Discussion
    Last Post: 07-11-2008, 09:59 PM
