Thread: 97 Alt Bracket on my 1999 GTP?
Results 1 to 20 of 33
  1. #1 Re: 97 Alt Bracket on my 1999 GTP?
    when removing it it dont just come out, you have to wiggle and pull, wiggle to much the timing cover breaks where the elbow enters the cover. now you looking a much larger job to change the timing cover out.
  2. #2 Re: 97 Alt Bracket on my 1999 GTP?
    I was able to keep the bigger 140 amp bonnie alt with a gen v, James mentioned he runs that step often and .. if you find the right year firechicken, it'll have a 97/98 alt looking bracket with both elbows removable.
    Wiggling the VC past is cake..
  3. #3 Re: 97 Alt Bracket on my 1999 GTP?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Are you only referring to the 97/98 style though? looking at my 99+ bracket, it looks like it hangs over the VC at least an inch or so
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #4 Re: 97 Alt Bracket on my 1999 GTP?
    hangover park IL
    Quote Originally Posted by 97AutoXVette View Post
    He's referring to the f body 99 bracket.
    the later f-body brackets...late 98 and 99 is the one that is horizontal bolts for the old larger alternators as well as having both elbows replaceable... ie the elbow is not integral like the earlier W body front wheel drive bracket
    ~James~ Psychotic Gearhead
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. N * Bracket
    By Makdaddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 09:13 PM
