Thread: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind engine
Page 8 of 8 FirstFirst ... 678
Results 141 to 160 of 160
  1. #141 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    those will work, rust and all.
  2. #142 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    SE Level Member zbban1's Avatar
    May 2014
    Mi
    Hi and welcome back to YOUR thread! My apologies for hijacking it (borrowing it sounds better...lol). Yes, I'm sure it isn't the sensor. I really wish it was the sensor because it's sooo much easier and cheaper to replace that than anything else that could be leaking oil.
    I would say those would be fine to use, a little rusty or not. A few of my tools look like that, too, because I have 3 sons who like to "borrow and not wipe off and return tools" to where they got them from. LOL
  3. #143 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    Ok guys/gals fixed the oil sensor. Working good no leaks
  4. #144 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Good to hear! In the process of moving, haven't gotten the chance to pinpoint my leak, but maybe someday.......
  5. #145 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Enfield, CT
    Put a dye in the oil and you'll find it
  6. #146 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Clean the engine and you'd find it..lol
  7. #147 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    my car is all good once changing the oil sensor. No more leaks
  8. #148 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Well, I'm FINALLY ready to do this oil pan gasket and motor mount! Seems like it's been forever waiting for the time to get to it, with moving and all, hopefully this weekend or next, really depends on if my sons have to work this Saturday or not.
    Anyway, just wondering if I have to put rtv on it or not? I got the felpro gasket that comes with the plastic windage tray, the gasket is rubbery-looking and blue. I asked the guy at the parts store and he said no.
    I've watched a bunch of videos on doing this pita job, is there anything I should be made aware of before we get ripping into this thing? lol
    I love the fact that I've got 3 strong, young sons that like to borrow money from Mom and when the time comes to pay me back, it's usually "Well, Mom, umm, errr". LOL That's when I pull my trump card and remind them that they can pay me back by installing things on my car for "free labor". Hey, it's a win-win situation...... They don't have to pay me the cash back and I don't have a huge labor bill at the local shop.
  9. #149 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Nobody can tell me if I need to put any type of RTV on with the new gasket/windage tray?
  10. #150 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    all I used was just regular grey permatex gasket sealer, put a lot on the pan, put the windage tray on, then more sealer, my motor was super clean tho so im not worried about sealing issues and the fact I used 2.5 tubes of gasket sealer on the whole motor build.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  11. #151 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Ok, thank you.
  12. #152 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Jun 2014
    Ontario Canada
    just make sure you clean your sealing surfaces with brake cleaner or something like varsol and try with a clean rag/towel
  13. #153 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Got plenty of cleaner and rags for this job...lol. Thanks.
  14. #154 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    We update on my status. Oil light came on. I checked the oil it was below the cross hatches on the dip stick where it says to add a quart. i was like I hope the oil sensor isnt leaking again, i checked it out and it was not. I put alot of miles on my car well over 6k since august when i changed the oil and sensor so maybe I burned a quart or 2 off
    i added a quart of oil and it brought to within the cross hatch marks right int he middle. Oil light didnt come back on so i figured it is ok and i dont need to put any more oil in it.
    Is it normal to burn a quart or 2 within 3 or 4 months of 6,000 miles worth of driving? When I put a quart in, it brought the level to the middle of the cross hatch
  15. #155 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Antioch, IL
    yes its normal, even newer vehicles the factory says losing 1 qt in between oil changes is acceptable... that is pathetic.
    2009 Challenger SRT8
    Expert at being gay.
  16. #156 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Gm says 1 quart in 3,000 miles is normal.
    I wouldnt go 6k on a oil change regardless, unless you are running a full syn. Both conventional oil and filters arent made to go that many miles.
    Fill it up to the top dot every time, which is 4.5 quarts during an oil change.
  17. #157 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    Quote Originally Posted by ITHURTZ View Post
    Thanks you all. so that would make sense. I have went roughly 6k miles so far
    I dont change my oil every 3k mile usually at least 6k miles or more with good high mileage oil. Oil these days are much better then decades ago and we no longer need to change oil every 3k miles
  18. #158 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    and you think the oil filter is good for double the life as well? change your oil man.
  19. #159 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Quote Originally Posted by Prixness View Post
    This motor had oil changes every 4K-5K
    This one every 3K
    Every 5K-6K
    While the properties of lubrication for oil is supposedly better, it still gets dirty and deposits still happen. Which motor would you want your's to look like?
  20. #160 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    GTP Level Member
    Aug 2012
    st louis park, MN
    I suppose I am literally betting my engine that Castrol full synthetic oil and a WIX filter is sufficient for 6k miles. I can see the parts through the valve cover hole look as clean or cleaner than pic #2 - I'm not sure what that would mean for the other internals.
    The oil loss mentioned above is normal and something I experience. Other vehicle manufacturers experience oil consumption as well.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. Wire hanging from under car near Passenger Side tire
    By gamefreak in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2013, 03:35 PM
  2. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  3. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  4. Passenger Side Leak
    By Toney Halbert in forum General Grand Prix Discussion
    Last Post: 03-13-2012, 09:13 AM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
