Thread: ticking exhaust sound with PLOG installed
Results 1 to 20 of 21
  1. #1 ticking exhaust sound with PLOG installed
    May 2008
    Winnipeg, MB
    I'm trying to remove the front exhaust manifold. I'm not getting the nut on the left just below the coil pack to turn at all. I'm convinced its a 13mm nut, my sockets or wrenches will not go on, I think its the heat shield not allowing me to get a good hold of the nut
    2007 Pontiac Grand Prix
  2. #2 Re: removing front exhaust manifold
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    same thing happened to me... just have to keep maneuvering the socket head until it goes on enough to turn it. The heat shield can get in the way just like you said.. Just have to go slow and eventually it will come off. Try putting some WD40 on it to soak the nut/thread a bit to help with the removal
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: removing front exhaust manifold
    May 2008
    Winnipeg, MB
    I got it off, put the PLOG on, now it ticks when I step on the gas
  4. #4 Re: removing front exhaust manifold
    Dec 2010
    DMV
    Leaky Leaky
  5. #5 Re: removing front exhaust manifold
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Check the bolts make sure they are tight.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: removing front exhaust manifold
    May 2008
    Winnipeg, MB
    I want to get the FEL PRO gasket, just have the oem gasket on right now
  7. #7 Re: removing front exhaust manifold
    Apr 2012
    Dayton, OH
    Keep the OEM on.
    2012 F150 STX
  8. #8 Re: removing front exhaust manifold
    Mar 2014
    Cincinnati, OH
    Keep the OEM on.
    thats what I did and haven't had any issues
    2002 GTP sedan:
  9. #9 Re: removing front exhaust manifold
    May 2008
    Winnipeg, MB
    the PLOG? it could be warped?
  10. #10 Re: removing front exhaust manifold
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by tod1d View Post
    can you pin-point where the leak/tick is coming from? closer to the flange connecting to the head? maybe the crossover connection?
    2002 GTP sedan:
  11. #11 Re: removing front exhaust manifold
    May 2008
    Winnipeg, MB
    what else could I do?
  12. #12 Re: removing front exhaust manifold
    May 2008
    Winnipeg, MB
    still ticks with either gasket, the bolts are tight, I have snapped some in the past so I know when to stop tightening them, not sure what else to do
  13. #13 Re: removing front exhaust manifold
    Have the manifold checked. Maybe it warped
  14. #14 Re: ticking exhaust sound with PLOG installed
    May 2008
    Winnipeg, MB
    not the crossover connection that is for sure
    could I use something like this?
  15. #15 Re: ticking exhaust sound with PLOG installed
    Mar 2014
    Cincinnati, OH
    I personally don't see why not.. But I am still surprised there is a tick.. Even with putting a layer of epoxy down, you still may end up having a path form for the exhaust to squeeze out of.
    If it were me, I would avoid the gasket-form and try a few more things first just in case
    2002 GTP sedan:
  16. #16 Re: ticking exhaust sound with PLOG installed
    May 2008
    Winnipeg, MB
    the ticking sound happens only when I step on the gas to accerlate, its fine at idle or crusing speed
  17. #17 Re: ticking exhaust sound with PLOG installed
    Mar 2014
    Cincinnati, OH
    spray some carb cleaner or WD around the manifold flange and fire it up to see if you can see bubbles forming in a certain spot to pin-point the leak. That'd be the next thing I would do. How bad is the ticking sound? noticeable from inside the car?
    2002 GTP sedan:
  18. #18 Re: ticking exhaust sound with PLOG installed
    Apr 2012
    Dayton, OH
    The plog isn't cracked is it?
    2012 F150 STX
  19. #19 Re: ticking exhaust sound with PLOG installed
    May 2008
    Winnipeg, MB
    yes the flange is warped, damn
  20. #20 Re: ticking exhaust sound with PLOG installed
    May 2008
    Winnipeg, MB
    took the PLOG to a machine shop, they wanted $150 to fix it, just said to toss it in the scrap metal bin
  1. FS-Front Exhaust Manifold and Crossover
    By K Kraziee in forum For Sale - Parts
    Last Post: 03-11-2014, 09:38 AM
  2. Front Exhaust Manifold Question
    By Shandley in forum General Grand Prix Discussion
    Last Post: 10-04-2012, 11:12 AM
  3. Front exhaust manifold bolts.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-30-2011, 09:52 PM
  4. Removing Exhaust Manifold
    By dgiles79 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-06-2010, 10:31 PM
  5. Front exhaust manifold change help
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 11:12 PM
