Thread: Brake & ABS Lights Coming On
Results 1 to 4 of 4
  1. #1 Brake & ABS Lights Coming On
    Sep 2012
    Las Vegas
    I believe I saw a similar post several years ago, but I can't find it.
    Anyway, roughly every other day the Brake & ABS indicators will come on in my '97. Sometimes they come on together, but not always. Sometimes it's the brake light only and other times it's the ABS light. Does anyone have any experience with this particular problem? I would appreciate any help you can offer, as I'm starting to go crazy. Thank you.
    p.s. I've played around with the parking brake to no avail.
  2. #2 Re: Brake & ABS Lights Coming On
    Aug 2011
    'Merica
    Check the wires that run into the hub for the ABS/Traction Control. They could be broken or in rough shape causing this issue. You can have the codes read and that would give you an idea on what corner you need to start looking.
  3. #3 Re: Brake & ABS Lights Coming On
    Sep 2012
    Las Vegas
    Thanks for the suggestion.
  4. #4 Re: Brake & ABS Lights Coming On
    Aug 2011
    'Merica
    NP..
  1. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  2. ABS ingauging when coming to normal stop - no lights on
    By albow77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 08:33 PM
  3. Fog lights coming on when i step on the brakes?
    By KadenGT in forum Visual/Body Modifications
    Last Post: 01-20-2012, 01:07 AM
  4. fog lights not coming on
    By 03limitedgtp in forum Visual/Body Modifications
    Last Post: 01-01-2012, 01:56 PM
  5. clicking coming from parking brake....
    By jakedidi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 03:42 PM
