Thread: 97 Alt Bracket on my 1999 GTP?
Results 1 to 20 of 33
  1. #1 97 Alt Bracket on my 1999 GTP?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Is it possible to run a early style W-Body bracket on my 1999 GTP?
    I am going to be swapping rockers within the next week or so and am wondering if I can put a 97 style alt. bracket on the car instead of the current one. I'd be looking to do this so if I replace rockers/springs/etc. again in the future, I won't have to keep pulling the bracket assy. off and draining coolant.
    Thanks for any advice
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: 97 Alt Bracket on my 1999 GTP?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I think you would still have to pull anyway I thought the only difference between them was the cast elbow.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: 97 Alt Bracket on my 1999 GTP?
    no you cant, not unless you also buy the alt for it. and why in the hell you want a cast elbow? they are a pita.
    and you dont need to remove the alt or the alt bracket to do rockers. i just installed a set last month.
    if your valve cover touches the bracket, loosen up the 3 bolts, and thats all you need to do, when done make em tight again, try not to play with it when its loose. i mean like 2 tunes loose just enough to get the cover off.
  4. #4 Re: 97 Alt Bracket on my 1999 GTP?
    on second thought, to bad your not closer, id swap mine for yours any day lol
  5. #5 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    haha... thanks for the info. I was actually reading earlier today that you can in fact just loosen up those bolts and back the bracket off ever so slightly to get the valve cover off. I am hoping that is the case!
    2002 GTP sedan:
  6. #6 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    Also, Scotty, I am guessing your 98 has the old alt. setup though?
    2002 GTP sedan:
  7. #7 Re: 97 Alt Bracket on my 1999 GTP?
    97/98 have that dumb cast lower elbow. so yup, i got one. my valve cover comes right off too lol
  8. #8 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    I'm thinking that I may have a bit tougher time with my valve cover clearing my 99+ style Alt. Bracket
    2002 GTP sedan:
  9. #9 Re: 97 Alt Bracket on my 1999 GTP?
    It's easy to get it to clear. I just did it the other day.
  10. #10 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    yours is the 98 style bracket though right? I believe the 99+ style protrudes further over the valve cover
    2002 GTP sedan:
  11. #11 Re: 97 Alt Bracket on my 1999 GTP?
    Scotty I have a 99+ style alt bracket that I'm not using adn the belt off a 2005 gt.
  12. #12 Re: 97 Alt Bracket on my 1999 GTP?
    Quote Originally Posted by 97AutoXVette View Post
    He has a 04 Compg.
  13. #13 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    Ahh.. good point. Thx
    2002 GTP sedan:
  14. #14 Re: 97 Alt Bracket on my 1999 GTP?
    Mar 2014
    Cincinnati, OH
    Looks like I will just have to give it a whirl this weekend and see how it goes!
    2002 GTP sedan:
  15. #15 Re: 97 Alt Bracket on my 1999 GTP?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    It works, ive got my 2000's bracket and alt on my 98 and its on my 2000.(gen 5 swap on 98)
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  16. #16 Re: 97 Alt Bracket on my 1999 GTP?
    he want to go the other way. 99 to a 97. bad idea lol
  17. #17 Re: 97 Alt Bracket on my 1999 GTP?
    The Boss Iceman6669's Avatar
    Jun 2011
    Personally I love the 97/98 style.. Means I only gotta replace one elbow.
    2011 F-150 Yote powered
  18. #18 Re: 97 Alt Bracket on my 1999 GTP?
    and risk breaking the timing cover every time you take off the bracket. thats the part i dont like.
  19. #19 Re: 97 Alt Bracket on my 1999 GTP?
    Jun 2011
    How do you risk breaking the timing cover?
  20. #20 Re: 97 Alt Bracket on my 1999 GTP?
    when removing it it dont just come out, you have to wiggle and pull, wiggle to much the timing cover breaks where the elbow enters the cover. now you looking a much larger job to change the timing cover out.
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. N * Bracket
    By Makdaddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 09:13 PM
