Thread: OBD Code O420 Help
Results 1 to 4 of 4
  1. #1 OBD Code O420 Help
    California
    Hi, Can a 0420 code be caused by a defective downstream O2 sensor?
  2. #2 Re: O420 Help
    Could it, maybe.
    But just about every single time it's still the cat converter that is no longer up to par with what the vehicle wants to see.
  3. #3 Re: O420 Help
    California
    The odd thing is I took it for the state emission test and with probe in the tail pipe all readings were way below the thresholds.The cat must be functioning correctly? The only reason it did not pass was that one monitor was not back on line as I had cleared the all the codes a couple of days before.
  4. #4 Re: OBD Code O420 Help
    California
    I just looked at the print out from the smog station again and all the readings are below normal. The catalyst checks good. Any ideas?
