WHEW! that's good......
The leak is so loud, I'm gonna guess it's not even hooked up. I found so much stuff on this car un hooked...........
What i meant was you remove the 2 or maby its 4 bolts from the radiator. Remove the lines from the condenser. Then you can push the radiator forward enough to slide the condenser out. The condenser is only like an inch thick. Its a tight fit but you don't have to remove the fans or the radiator.
Thanks. I'm going to take a closer look this evening.
Hey guys my ac works but my problem is it only blows to the floor instead of the regular vents, even tho it's not on feet mode. Anyone know what I can do I really need this fixed I live in Texas and its HOT out here
Machete, whatcha driving?
2000 gtp
On top of the SC there is a vacuum line that goes back to the firewall and over the passenger strut tower. Fix it with rubber tube where it's broken.
I'll give that a shot, I hope thats it!!!
