Thread: NGK Spark Plugs
Results 1 to 5 of 5
  1. #1 NGK Spark Plugs
    Dec 2012
    Canada
    Can anyone tell me for sure if NGK TR5 Spark Plugs are identical in heat range to NGK TR55, as I have been informed that the only difference is gap size, is this correct?
    If the heat range is identical, is it also the identical heat range to an Autolite 104 spark plug?
    I am presently seeing 1.5* at WOT with my present setup with Autolite 605's installed and am considering going to a colder plug.
    2002 - GTP, KN-CAI, Autolite 104, Magnaflow CatBack, ZZP 3" DP, ZZP-Plog, Overkill Tune, ZZP MPS 3.6" pulley, Don Rome STB, Mobil 1 Syn, Transgo Shift Kit, Flipped Dogs.
  2. #2 Re: NGK Spark Plugs
    605's should be just fine for your mods, but going 1 step colder won't hurt anything. I doubt much will change.
    But TR5 and TR55 are pretty much the same, I think the TR5's come in a .040 gap already, so it's smaller.
  3. #3 Re: NGK Spark Plugs
    Dec 2012
    Canada
    Thanks for your reply but are the NGK TR5 the same heat range as Autolite 104?
  4. #4 Re: NGK Spark Plugs
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by GTPJIM View Post
    No
    An AL 104 is two full ranges colder than stock while a NGK TR5 is only one full range colder than stock.
    http://www.oqcgp.com/phpbb3/viewtopic.php?f=44&t=37950
  5. #5 Re: NGK Spark Plugs
    Dec 2012
    Canada
    Thanks so much for the reply and the link.
  1. Spark plugs?
    By 1998GRANDPRIX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2013, 10:06 AM
  2. spark plugs?
    By WDEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2013, 12:58 PM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. spark plugs
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 10:49 AM
  5. spark plugs
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 12:32 PM
