Thread: Trans chattering?
Results 1 to 4 of 4
  1. #1 Trans chattering?
    SE Level Member 04whitegtp's Avatar
    May 2014
    Lansing Michigan
    My 04 comp g has been making a odd sound. Not sure what is going on. When I do a wot in first gear, when it shifts it feels like the trans chatters. Can anyone pinpoint whats happening.
    Mods are: 3.5 pully, 180 tstat, cold air intake, zzp 1.0 pcm, and auto lite 103's.
    Thanks.
    Using Tapatalk
  2. #2 Re: Trans chattering?
    Where is the chattering coming from, if you can pinpoint that.. it would make pin pointing your issue easier. Do you believe it's pressure on a CV that's chattering?
  3. #3 Trans chattering?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Would this be your sound ??
    http://s294.photobucket.com/user/lil...0AC10.mp4.html
    2004 Grand Prix GTP 150,000 " The New Edition "
  4. #4 Re: Trans chattering?
    May 2014
    Lansing Michigan
    No, you can barely hear it. And it only does it occasionally. Its more of a vibration in the steering wheel. I did just rotate my dog bone bushings. Could it be that im just noticing it more now?
    Using Tapatalk
  1. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  2. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
  3. DRL and relay chattering in 2002
    By smitz327 in forum Visual/Body Modifications
    Last Post: 03-29-2013, 05:03 PM
  4. Brake Chattering/Clicking ........Solved.
    By moddman in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2012, 01:31 AM
  5. Front end chattering on take off.
    By atruebudfan in forum General Tech Discussion
    Last Post: 06-02-2010, 10:05 PM
