Pulled code "P0341" from a bluetooth dongle that hooks up to the OBD II port through my phone using the Torque App.
Any good write-up on checking/replacing the cam sensor?
What do I try next? Any suggestions?
I'd search for the code P0341 here on the site. Comes up often. I'd start by checking the wiring to it. If good, then might be time to replace it. I'm pretty sure you will need a Case relearn after replacing it, which requires a Tech II scan tool (shop or dealer).
To do it..I'll pull the belts
Undo the 10mm holding it
Find a way to wiggle it out
Stick my finger in the hole and have a buddy rotate the motor super slow (feeling for cam magnet)
Once you feel the magnet..
Wiggle new sensor in
Reconnect it
Got that code sorted, for now. The clip on the wiring harness had broken off and the plug to the sensor had come loose.
Cleared the codes, and it hasn't come back in 3 days of driving.
New problem is I struggle to get 16mpg driving like there's a land mine under the accelerator
