I have been getting P0332(low voltage from Knock Sensor, 2nd bank) CEL for the past month or so. I have since replaced the KS, replaced the wire and I just cleaned the PCM connecting terminals. Nothing has fixed the issue. I checked the Voltage coming from the PCM to the KS and I got 3.35 Volts, i believe it should be closer to 5 volts, the KS is supposed to cut the voltage in half and return that to the PCM.
I have no idea what could be wrong, could the PCM be bad?
