Thread: P0341
Results 1 to 4 of 4
  1. #1 P0341
    Aug 2011
    Birmingham, AL
    Pulled code "P0341" from a bluetooth dongle that hooks up to the OBD II port through my phone using the Torque App.
    Any good write-up on checking/replacing the cam sensor?
    What do I try next? Any suggestions?
  2. #2 Re: P0341
    St. Louis
    I'd search for the code P0341 here on the site. Comes up often. I'd start by checking the wiring to it. If good, then might be time to replace it. I'm pretty sure you will need a Case relearn after replacing it, which requires a Tech II scan tool (shop or dealer).
  3. #3 Re: P0341
    To do it..I'll pull the belts
    Undo the 10mm holding it
    Find a way to wiggle it out
    Stick my finger in the hole and have a buddy rotate the motor super slow (feeling for cam magnet)
    Once you feel the magnet..
    Wiggle new sensor in
    Reconnect it
  4. #4 Re: P0341
    Aug 2011
    Birmingham, AL
    Got that code sorted, for now. The clip on the wiring harness had broken off and the plug to the sensor had come loose.
    Cleared the codes, and it hasn't come back in 3 days of driving.
    New problem is I struggle to get 16mpg driving like there's a land mine under the accelerator
  1. P0340, P0341 camshaft sensor
    By johndaysGT in forum 5.3L V8 (LS4)
    Last Post: 12-21-2013, 07:28 PM
  2. P0341 help!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 10:53 AM
  3. P0141 p0341 p1351
    By jkwidener in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2011, 08:22 PM
  4. Error codes p0341 and po300
    By jessiinicole in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 04:34 PM
  5. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
