Thread: Swapping engines in a '99 and '00
Results 1 to 5 of 5
  1. #1 Swapping engines in a '99 and '00
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    So I have two Grand Prix's one a '99 four door and a '00 two door. I recently bought the 1999 and after a few tests we can say I threw a rod in the engine. Is there a difference between the engines that would stop me from being able to swap the engine?
    Then I have another question, since I threw the rod I bought another engine it's another 3.8l but this was has a supercharger in it. I heard after I bought it that it may be a hell of a time for me to change all the wiring on the vehicle to even get the engine to work? If it is possible to swap the engine could you kind of tell me everything that I would need to purchase to put the supercharger into the engine. ~Another idea I have was taking the supercharger off of the engine then just putting into the engine that is in the car so I dont have to do a full swap.
    Any ideas will help, sorry if this is in the wrong area, it was a broad range of engines and questions. Any help will be greatful!
  2. #2 Re: Swapping engines in a '99 and '00
    yes the engine swap will work.
    not sure what you want to do with the sc engine? why not just use it whole? cheaper then taking the top off it and swapping it over to a n/a block. far less work involved thats for sure.
    if you only bought a super charger you'll need the heads off a sc engine the fuel rails the pulleys and so on.
  3. #3 Re: Swapping engines in a '99 and '00
    Jun 2014
    United States
    I bought the entire SC engine so I will just need all the other little things to make the car work with a supercharger. Wire harness and all the other stuff. This will be my first ever swap with anything like this and im not the best person with engines thats why I just wanted to see what I would all need, im going to have my friend who is wayyy more mechanically inclined than me to help me.
  4. #4 Re: Swapping engines in a '99 and '00
    There are a lot of threads here about a top swap. You could use them as reference on what changes from a NA to SC motor being in a car.
    The short list of what changes:
    Flex plate to converter (SC converter is 258mm and NA is 245) so you swap a flex plate.
    Change the connector going to the map sensor and extend it. (Can buy pigtail at parts stores/ebay)
    Get pcm tuned for SC
    Leave boost control soleniod unhooked so the vacuum controls it.
    That's about it.
  5. #5 Re: Swapping engines in a '99 and '00
    Jun 2014
    United States
    Thanks for the info guys, im hoping to build the engine and have fun with people at the track!
  1. Swapping out engines
    By Wolfpack in forum General Tech Discussion
    Last Post: 11-01-2012, 01:50 PM
  2. Engines??
    By Speedy1973 in forum Off Topic Discussion
    Last Post: 05-18-2012, 10:00 PM
  3. How hot are l67 engines supposed to get?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2010, 09:02 PM
  4. What vin 1 engines.....
    Last Post: 06-16-2010, 08:03 PM
  5. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
