Thread: 04+ aftermarket gauge lighting
Results 1 to 2 of 2
  1. #1 04+ aftermarket gauge lighting
    May 2013
    Upstate NY
    So I finally finished my gauge install. I needed a wideband to tune with so I went with a PLX, and seeing how I had two more holes in my triple pillar pod, I filled those with an autometer phantom oil pressure gauge and because I wanted to feel like Paul Walker living the fast and furious lifestyle I put the matching boost gauge in too. I have everything hooked up and working great, except my lighting. I bought red LEDs to light my gauges bc they'll look close to the stock gauges. I would love to hook them up and have them dim with the rest of the gauges but I for the life of me cannot figure out how. I read the schematic and found out that a gray wire supposedly carries the power to all the dash lights but when I check with my test light I don't get any voltage. So my question is, where are you 04+ guys hooking up your aftermarket gauge lights? Thanks!!
    04 CompG, black HAI, 180*, TR55s, custom tune by me, SD headers soon
    04 CompG, fusion orange, all stock
    99 GTP, red, coupe, 3.4, SLP exhaust, basic mods, PB 13.56, SOLD in 09.
  2. #2 Re: 04+ aftermarket gauge lighting
    SE Level Member wyoprix's Avatar
    cheyenne wy
    hook to the assesory fuse on the passanger side fuse box
    2007 gt 3.0 mps 0-KR headers 3''dp cat res delete 44 injectors 85MAF stage 3 intercooler 108 t stat cold air, overkill pcm, aeroforce gauges tripple pillar, rims tint, trans cooler intense shift kit, yella terra 1.9 roller rockers 105 crow springs, 104 plugs, 7'' pioneer screen 1000 watt rockford amp an two 10" P3's cusom box & more
  1. gauge lighting
    By 2004GrandPrixGT1 in forum Visual/Body Modifications
    Last Post: 12-29-2012, 04:08 PM
  2. Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    By WaterBoy in forum General Tech Discussion
    Last Post: 02-07-2012, 09:55 AM
  3. Dash Gauge Lighting
    By Rhino515 in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2010, 11:44 AM
  4. where to buy aftermarket lighting
    By jersey jok3r in forum Visual/Body Modifications
    Last Post: 03-15-2010, 02:13 PM
