Ok guys need some advice tryna open my car hood to charge my battery to unlock with my remote because my battery died and my relative left my key in the ignition smh real "smart".. any ideas thanks!!!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Tell said relative that's he or she is a dumbass for leaving your keys in the ignition and needs to fork up the money and call the locksmith.
Pop one of the grilles out and you can reach back there and unlatch it.
You can try to get the window down enough where you can take a coat hanger and try to shimmy it down enough to pull the door unlock.
Call the locksmith give them your vin they may be able to provide you a key w/ the microchip.. Just so you can unlock your door won't start the car or anything but helpful in situations like this.
A lot of times you don't even have to pull the screws out. The grilles and screw inserts (that pop into the bumper, what the screw goes in) will pop out in one piece. But if you have acess to a screwdriver, definitely the way to go.
Dealer cut the key for my 99 for $1.50 from the vin.
So there is a latch I can pull? Any pics guys?
Thanks guys just in case anybody is trying to attempt tthis it is there is a spring in between you have to hit it to the right with a screwdriver and the hood will release
