Thread: heater problems/no heat
Results 1 to 12 of 12
  1. #1 heater problems/no heat
    Dec 2008
    dewitt
    lately i have been trying to use the heater in my car. and it only works on the defrost mode but just barly. i have no clue whaat it could be. it just warm air, and also on all the modes like feet or heat or even defrost it only comes out the passanger side and on the driver side its cold air. ive checked the inlet and outlet hoses and the're just nuke warm. not hot. any advice would be amazing. its freezing and i need the heat really bad. thanks guys.
  2. #2 Re: heater problems/no heat
    Apr 2008
    Chillin at the Beach , VA
    First I would check the blending door. A llot of times, over the years, they'll get dirt and grim on them and stick. If that's not the probllem, then I would move to the controls.
  3. #3 Re: heater problems/no heat
    SE Level Member Mikefisher's Avatar
    Winkler,Manitoba,Canada
    I have somewhat of the same problem.First I was getting little to no heat so I changed my thermostate and that fixed the heat thing but, I dont get alot of air flow to my floor.I can get it blowing like crazy everywhere else but the floor?Any thoughts
    Pike---- Family of rapacious,malevolent,razor-toothed freshwater game fish that will strike instantly and violenty at just about any lure you decide not to try...
    http://s43.photobucket.com/albums/e381/mikefisher99/
  4. #4 Re: heater problems/no heat
    Apr 2008
    I am not sure if the blend door is for that as well, but you can check that and see if there is another one that controls the flow to the floor. O haven't been that far into the system to know for sure.
  5. #5 Re: heater problems/no heat
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  6. #6 Re: heater problems/no heat
    Apr 2008
    Good looking out gtpinsc. I won't even thinking about that.
  7. #7 Re: heater problems/no heat
    Jul 2008
    Quote Originally Posted by BADAZGTP View Post
    i do what i can.
  8. #8 Re: heater problems/no heat
    SE Level Member schreurs1's Avatar
    Dec 2008
    sioux falls, sd
    the blend door is probably the most likely cause of the no heat to floor issue. if it is mechanically actuated check the linkages cuz they tend to break. if its elecrically operated the actuater or servo that operates that door may be bad. also check cabin filter, that causes some low air movement when fan is on high.
  9. #9 Re: heater problems/no heat
    Dec 2008
    dewitt
    i get air blowing to all the modes just not alot of heat. but could the theromstat be bad it it runs at opperating temp? cuz it does.
  10. #10 Re: heater problems/no heat
    make sure everything is ok with your radiator/thermostat/fluid etc. My coolant elbow took a dump and I lost a lot of fluid, on the way to Brian's for repair, I noticed that the heat would blow only mildy warm, then cool, then warm. Heater core was acting up under those conditions.
  11. #11 Re: heater problems/no heat
    Dec 2008
    dewitt
    ive been told by some machanics that if im getting some what warm air then the heater core isnt bad. i just changed the controls today and that didnt seem to make a difference. im going to try the thermostat but i rly dont think that is the problem.
  12. #12 Re: heater problems/no heat
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to the tech section
  1. heater problems/no heat
    By cartkid14 in forum General Tech Discussion
    Last Post: 12-22-2008, 11:22 PM
  2. '05 Prix Heat Problems
    By Breezy in forum General Tech Discussion
    Last Post: 12-11-2008, 10:09 AM
  3. Air and heat problems
    By chrizzle17 in forum General Tech Discussion
    Last Post: 12-10-2008, 08:28 PM
  4. Cut off heat shield?
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:03 PM
  5. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
