Thread: please help Grandma!!!
Results 1 to 12 of 12
  1. #1 please help Grandma!!!
    Mar 2012
    Michigan
    Help!!!!
    Could some please give me step by step instructions on how to change the top engine mount strut bracket on the passenger side of my
    01 Pontiac grand prix 3.8L and it's not supercharged....the bracket broke..and I'm stranded in another state...someone out there to help a grandma out....Thank you
  2. #2 Re: please help Grandma!!!
    if you look at the part thats still on the engine under the fuel rail you'll see 2 bolts, they are in a tight spot with the rail there, but can be removed with ratcheting gear wrench.
    you can still drive the car till you get the new part. just avoid hard starts from a dead start, drive it softly so to say.
  3. #3 Re: please help Grandma!!!
    Mar 2012
    Michigan
    Would like to get instructions on how to remove it so I can fix it
  4. #4 Re: please help Grandma!!!
    Mar 2012
    Michigan
    From the front all the way to the side of the bracket up to the top back bolt is broken...wish I could get the picture to download in here
  5. #5 Re: please help Grandma!!!
    its rather straight forward, remove bolts replace it.
  6. #6 Re: please help Grandma!!!
    Wow, you are so helpful.
  7. #7 Re: please help Grandma!!!
    If you remove the mount from the rad to the broken piece it's two 15mm bolts with 15mm nuts. Once that is out of the way. On the front of the black metal should be two 15mm bolts holding that to your broken piece. Remove them, then remove the 13mm nut down by the spark plug on the same black metal piece.
    Now all you have is your two bolted down broken parts. I believe these are 13mm, but likely they are 15mm. The one closest to the passenger side is straight forward for removing. Now the tough one is next to the fuel injector. The easy way is to undo the 4 10mm nuts holding down the injector rail and lift it up.. then the bolt is easy. If you would prefer to leave the rail in place.. you can do it very slowly with an open end wrench.
    To instal
    Put your new aluminum piece in place and put in the last two bolts you just removed, before you tighten them fully, bring the black metal piece in place to the exhaust stud (13mm nut) and start the two 15mm bolts through the black bracket and into the aluminum. Once those are all started, now you can tighten all of them and your first two bolts. Bring your motor mount to the front back in place and bolt it up with it's two bolts/nuts.
    All set
  8. #8 Re: please help Grandma!!!
    Mar 2012
    Michigan
    Thank you so much BillBoost37...your the man!...
    Will give it a try
  9. #9 Re: please help Grandma!!!
    Mar 2012
    Michigan
    What size open end wrench do I use can't get the back bolts off
  10. #10 Re: please help Grandma!!!
    Mar 2012
    Michigan
    I did it...boy was it a pain to unloosen those back bolts...Thank you so much for your help!..
  11. #11 Re: please help Grandma!!!
    Glad it worked out for ya.
  12. #12 Re: please help Grandma!!!
    Told ya it would be a pain. And .. uh I had mentioned it was either a 13 or 15.
  1. Grandma Wagon Kill X2
    By machinegunsquid in forum Track Sessions and Kills
    Last Post: 06-02-2011, 10:07 PM
  2. The Grandma Wagon Strikes Again.
    Last Post: 02-12-2011, 11:04 AM
  3. Grandma wagon vs. Civic
    Last Post: 03-15-2010, 08:12 AM
  4. One cool Grandma
    By silverstreak in forum Off Topic Discussion
    Last Post: 02-20-2010, 08:47 PM
  5. 7 y/o steals grandma's SUV... hilarious
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 05-20-2008, 11:39 PM
