Thread: Engine Cut's Off
Results 1 to 19 of 19
  1. #1 Engine Cut's Off
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    So my dad has a '02 grand prix N/A GT and a while back it would shut off while driving down the highway...sometimes it will crank back others it'll take up-most an hour til it fires back up...Basically it just dies...almost like its not getting fuel or sometype of power to fire the pistons...
    I told him about this website and he wanted me to ask a few of you guys about this issue...
    we orginally thought it was the fuel pump so he bought a new one and we installed it but last week it did it again...
    any of you guys had this problem or know an easy around-the-house checks and maintaince?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Engine Cut's Off
    Barksdale AFB, LA
    Random stalling is usually caused by one of two things. Bad crank position sensor, or a bad ignition switch.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Engine Cut's Off
    Oklahoma
    I would lean more to the Crankshaft Position Sensor.
    I guess one way to isolate it would be to ask if you have all your fan speeds on the HVAC and if you have had any trouble with the Accessories. If the ignition switch is failing I would expect something along those lines to show up.
    To isolate it to the Crankshaft Position Sensor, the next time it dies and has trouble starting up, take off the #1 cylinder plug wire and put in a spare spark plug and ground it (They sell a test tool in the parts store for doing this) rather make sure the threads or the metal part is touching ground and try and start the car. If you have no spark it is most likely the CPS as that is a common failure item for the GP's. The CPS controls spark and also the tachometer. So if you are seeing your tach signal go to 0 on the dash, thats another indication that the CPS is bad.
  4. #4 Re: Engine Cut's Off
    Barksdale AFB, LA
    Yeah, usually with the ignition switch the accessories will shut off with the engine (since the car thinks it was turned off) and come back on when you try to restart.
  5. #5 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    k good suggestions...be sure to try these and see
  6. #6 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    we're going to try and change the crankshaft position sensor....can anyone please tell me where to locate it?
  7. #7 Re: Engine Cut's Off
    Oklahoma
    Theres a write up in the How To section that walks you through the process. The CPS is behind the crank pulley otherwise known as the harmonic balancer.
  8. #8 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    thnx syntheitic, the part is $36.99 at autozone...i'll show him the write up, first thing tomrrow...
    http://www.grandprixforums.net/cps.php
  9. #9 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    UPDATED: thanks all you guys...just so happens to be the CPS...we changed it out and the car runs fine now.
  10. #10 Re: Engine Cut's Off
    Oklahoma
    I have seen so many of those things fail, I think I have it down to a near science being able to tell when they go bad.
    offroadfury6, do you still have the old sensor? If so can you take a pic of it? If its the of the design I think, Id be willing to take it off your hands and pay for shipping if you want to part with it.
  11. #11 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    I just got in today syn, I'll get up with him tonite...he says he may have it in the back of the SUV
  12. #12 Re: Engine Cut's Off
    Oklahoma
    Cool, if so, let me know.
  13. #13 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
  14. #14 Re: Engine Cut's Off
    Oklahoma
    Thats it, let me know what you want for it and/or what shipping would be to 74006.
  15. #15 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    nah its so small man i'll probably just ship it all for free...might need a favor from ya one day ... just send me a PM of ur address and I will see if I can pop it in tomorrow or after christmas, depending on my schedule...
  16. #16 Re: Engine Cut's Off
    Oklahoma
    PM Sent.
  17. #17 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    roger that
  18. #18 Re: Engine Cut's Off
    Aug 2008
    Fayetteville, NC
    don't have a box handy for ya...will get it to ya n maybe a few days syn
  19. #19 Re: Engine Cut's Off
    Oklahoma
    Sounds like a plan, Im in no particular hurry.
  1. Engine Rpm
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 12:36 PM
  2. Now that the engine is out....
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2008, 01:13 AM
  3. Engine Bay Pics
    By BKA05GT in forum Visual/Body Modifications
    Last Post: 05-27-2008, 12:23 PM
  4. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  5. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
