Thread: How do I take this off?
Results 1 to 12 of 12
  1. #1 How do I take this off?
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    How do I remove this egr tube from the exhaust manifold? I bought the backing plates from zzp and the intake one had a 13mm bolt that just comes right off, but the exhaust side looks like it is like welded into the plate. I tried a 13mm socket and it just turns cuz its like welded on or something. Guys got any advice?
    Sent from my PantechP8010 using Tapatalk
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: How do I take this off?
    reach around the other side where the bolt head is located.. it's either a 10mm or 13mm
  3. #3 Re: How do I take this off?
    Apr 2013
    Milwaukee
    I can't for the life of me get this off. I'll pay someone $50 to come do it for me lol
  4. #4 Re: How do I take this off?
    its a nut and bolt, so on the back side is a bolt head, and then theres the nut you can see. so you need 2 wrenches. or a wrench and a socket.
  5. #5 Re: How do I take this off?
    Apr 2013
    Milwaukee
    But the bolt on the back is like stripped and the front where the tube starts on the bottom where I took the pic, no wrenches or sockets fit on there. It's like a circle
  6. #6 Re: How do I take this off?
  7. #7 Re: How do I take this off?
    Apr 2013
    Milwaukee
    Like the whole piece where the tube connects too?
  8. #8 Re: How do I take this off?
    The bolt ..is out of sight. It is at an odd angle and requires a bit of trying. If it's stripped, then you are effed. The side you can see is a flange like Bio said and there's no turning it.
    Only other way to get that out, besides turning the bolt the proper direction, is grind it off.
  9. #9 Re: How do I take this off?
    bet you're using the wrong socket, not it being rounded off.
  10. #10 Re: How do I take this off?
    Apr 2013
    Milwaukee
    I was able to get it off with a 10mm socket. It was such an awkward angle so I had to lower the wrench in slow so I did't drop my extension. Came off with some force. I hope black silicone rtv is ok cause that's what I used. I should've picked up high temp stuff, but I already had a bottle of the black stuff. BTW thanks for the advice guy's.
  11. #11 Re: How do I take this off?
    NP, we like to help out.
    Reason for me mentioning it's either a 13 or 10 was so you'd have the right tool. Either the socket will be too small, too big or just perfect.
  12. #12 Re: How do I take this off?
    Apr 2013
    Milwaukee
    Ya, I was futsing around with a 13mm and it seemed like it was the size, probably caught it on an angle that's why I thought it was stripped. Put the ten on and it took some force, but finally budged.
