Thread: Leaking gaskets need diagnosed (with pics)
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 228
  1. #61 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Just make sure they have the size you need in the set, made that mistake before.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  2. #62 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Just degreased my engine. Project will be worked on tommorow. Im gonna just go ahead and use the flush kit so am I right in the picture that the top hose is the heater inlet hose?
    Sent from my SCH-I545 using Tapatalk
  3. #63 Re: Leaking gaskets need diagnosed (with pics)
    as the car warms up, touch both hoses, the one that is hotter is the in line
  4. #64 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Scottydogs, in your coolant flush method, all you do is remove the hose that goes to the tstat and put it in a bucket to drain etc etc? I dont even need to touch the lower rad hose?
  5. #65 Re: Leaking gaskets need diagnosed (with pics)
    take the t stat out, then put the housing back on. then leave the hose on the t stat housing, and take it off the rad. it will pump out the upper hose to a bucket or the ground.
  6. #66 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok. Should I drain from the drain plug first at at all or not?
    Edit: Seems pretty obvious that I need to...correct?
  7. #67 Re: Leaking gaskets need diagnosed (with pics)
    why bother? it will break most of the time. the water pump will pump all the old coolant out for you. and flush the clean water through.
  8. #68 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok...just dont want coolant leaking everywhere after I remove hose and try and get it into the bucket
  9. #69 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Got tstat housing off now scraping off old gasket. Is it bad if parts of it fall into the tstat housing hole?
  10. #70 Re: Leaking gaskets need diagnosed (with pics)
    dont bother with that gasket till the lim is off the engine. if your just taking out the t stat at this point put the housing back on with the old gasket still there or nothing at all.
  11. #71 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok already scraped it so I shouldnt put on my new one yet? Just go with nothing?
  12. #72 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Finally got that hose off. Ready to begin flush.
  13. #73 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Guys I have a huge problem. Puddles of coolant began flowing from virtually everywhere under the car. Huge mess got it cleaned up but what could be going on???!
  14. #74 Re: Leaking gaskets need diagnosed (with pics)
    from the t stat area, due to no gasket? only place it should be leaking from during a flush.
    dont use the new gasket till its the final time the t stat housing goes back on.
  15. #75 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Yes the tstat gushes coolant everywhere. What do I need to do?
  16. #76 Re: Leaking gaskets need diagnosed (with pics)
    keep flushing till clear water comes out the upper hose lol.
    then blow off the lim as best you can, use a leaf blower if need be. ( house vacuum on blow what ever you got to dry it up) then get to work tearing it apart.
    make sure once its clear water out the upper hose you stop feeding the rad with new water, and run it till no more water comes out the upper hose. shut it off.
    then pull the lower hose, pull them dog bones, rock the engine back and fourth and then start taking it apart.
  17. #77 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    I think I'm not gonna mess with the lower hose cuz I'm going to do an oil change afterwards regardless
  18. #78 Re: Leaking gaskets need diagnosed (with pics)
    taking the lower hose off the engine is so the block can drain, as well as the lim. you want to try as hard as you can at all times to avoid any coolant or water to get into the engine. even if your doing a oil change afterwards.
    if your doing valve cover gaskets too, your taking the coil bracket off too, once thats off the hose clamp is easy to get to.
  19. #79 Re: Leaking gaskets need diagnosed (with pics)
    oh, i did put a normal hose clamp on that hose after i got it off the first time. its way easier to get a nut driver in there to open or close the clamp.
  20. #80 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Oh so im taking the hose off the engine, not the rad
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
