Thread: Fuel pump resistor jumper connector? (Caspers kit)
Results 1 to 5 of 5
  1. #1 Fuel pump resistor jumper connector? (Caspers kit)
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    So, I am in the process of installing my fuel pump hot wire kit made my Caspers. I am about to replace the stock fuel pump resistor in my 1999 GTP, when I look in the kit, and can't find the resistor jumper connector anywhere...
    has as anyone else who has installed one of these come across this same issue? Maybe they forgot to include it??
    please help!
    thank you!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Fuel pump resistor jumper connector? (Caspers kit)
    I break stuff selliott's Avatar
    Kansas City
    I've had 2 caspers kits one came with the jumper and one did not. Did you get it from intense?
  3. #3 Re: Fuel pump resistor jumper connector? (Caspers kit)
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by selliott View Post
    Yes I did.. What do you recommend? Did your kit come with a jumper like that shown in the picture??
    2002 GTP sedan:
  4. #4 Re: Fuel pump resistor jumper connector? (Caspers kit)
    Kansas City
    The second kit did. If you need one just call intense most likely he will send you one at no charge. They are a great bunch of guys over at intense they have always been very helpful.
  5. #5 Re: Fuel pump resistor jumper connector? (Caspers kit)
    Mar 2014
    Cincinnati, OH
    Okay, they're not open again till Monday. In the meantime, can I just put a wire in the two prongs where the resistor would normally connect to?
    also, another issue... The toe connectors going to the fuel pump. 1 is correct, and clips in just fine. The other is a 4-prong, stock is 3-prong... Did anyone come across this as well??
    2002 GTP sedan:
  1. Caspers Fuel Pump Hotwire Kit... Pros/Cons
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 06-09-2013, 02:13 PM
  2. where do i buy fuel pump resistor
    By grhein in forum General Tech Discussion
    Last Post: 07-12-2011, 01:12 PM
  3. fuel pump resistor
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:19 AM
  4. Fuel pump connector diagram
    By Justinzoso in forum General Tech Discussion
    Last Post: 08-31-2010, 09:42 AM
