Thread: Freon+working compressor= no cold air??
Results 1 to 20 of 27
  1. #1 Freon+working compressor= no cold air??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    So ive had this problem for about a month and haven't looked to deap into it until recently, now that its 106 out. So I just replaced the majority of the a/c components about 6 months ago and everything worked great. I thought maybe I didn't tighten something down enough and I had a leak so I tried refilling it and the system says its full and it did squirt out a little freon when I connected the hose. The a/c clutch also engages and disengages exactly as it should so I don't know what the problem is. I should mention I have a 99 with the digital dual climate control.
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Freon+working compressor= no cold air??
    Are the blendor doors working?
  3. #3 Re: Freon+working compressor= no cold air??
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I've seen where the pressure switch wiring is corroded where it goes into the harness. Also maybe a bad pressure switch. Do you have gauges to read the pressures?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  4. #4 Re: Freon+working compressor= no cold air??
    Oct 2015
    Quote Originally Posted by rickisrad View Post
    I will have access to real gauges next tuesday, all I have now is the can refill gauge. That gauge says its full though and there's definitely a good amount of pressure in the system when I push down on the Schrader valve on the low side port.
  5. #5 Re: Freon+working compressor= no cold air??
    Oct 2015
    Yes also the a/c line in the engine bay doesn't even get the slightest bit cold
  6. #6 Re: Freon+working compressor= no cold air??
    St. Louis
    Really need to see what both sides of pressure are to figure it out. Might be overcharged.
  7. #7 Re: Freon+working compressor= no cold air??
    Oct 2015
    Well I emptied out the system obviously in a completely legal way. I noticed that it started spraying some freon or oil or something but then the whole rest of the time seemed to be just air so now I'm guessing there is a leak and the system was just pressurizing air making the gauge read full.
  8. #8 Re: Freon+working compressor= no cold air??
    Nerp.
    Freon is a gas when it hit's outside air/no pressure, it will just look like compressed air behind shot out. The oil is the pag oil that lubes the pump and seals.
  9. #9 Re: Freon+working compressor= no cold air??
    Oct 2015
    Nerp.
    What if the freon you use has dye in it? Wouldn't it come out colored then rather then just like air?
  10. #10 Re: Freon+working compressor= no cold air??
    Oct 2015
    Ok guys I need help. I hooked some actual gauges up to it. Before hand I evacuated everything in the system. Refilled with freon, hooked up gauges and low side is reading normal but high side isn't anywhere near what its supposed to be its very low. When I turn on the compressor the low side dips a little bit and then returns to the previous reading. The high side pressure never builds. The compressor is only a few months old and was working originally and it does turn on or atleast the clutch engages. Is my compressor some how bad even though it turns on or might I have a bad expansion valve or something?
  11. #11 Re: Freon+working compressor= no cold air??
    St. Louis
    No, the dye is usually UV dye and will not change the color of a gas. What you need is some UV glasses and a UV light to check for leaks if that is what you put in the system.
    When you drew a vac on the system, how long did you vac it and what did it draw down to? How long did it hold the vac after stopping the process? How much Freon did you put back in?
    I'm far from an A/C expert but I've dealt with mine (and others) enough to know some. What pressures were you seeing on the low and high side? What was the ambient temp and humidity?
  12. #12 Re: Freon+working compressor= no cold air??
    Oct 2015
    Its 100* out and we were seeing avoit 45psi on both the low and high side with the compressor on or off. The only thing that happened when we turned the compressor on is the low side pressure would drop to maybe 10psi for a second or 2 and then go back up to 45. The high side never changed. We evacuated the system for 40min I'm not sure what the pressure was at after. I put approximately 18oz of freon
  13. #13 Re: Freon+working compressor= no cold air??
    Oct 2015
    Despite the compressor being farely new and it looking like its working my dad seems to think there's something wrong with it since the high side isn't building pressure so we are on our way to the store to swap it out under warranty
  14. #14 Re: Freon+working compressor= no cold air??
    Nov 2012
    Madison
    You should really hook up the vacuum pump before anything else.
    You have to know it can pull a vacuum to 30hg and hold it. You have to do this to make sure you have boiled the moisture from the system.
    If it doesn't pull down that far or hold the vacuum you have a leak.
    Leave the pump on until it gets to 30
  15. #15 Re: Freon+working compressor= no cold air??
    Oct 2015
    Ok we are re evacing the system now and its almost at 30 so I will keep you updated. Thanks for all your help guys
  16. #16 Re: Freon+working compressor= no cold air??
    Nov 2012
    Madison
    I should have said shut the pump off when its on 30 and see if it will hold
  17. #17 Re: Freon+working compressor= no cold air??
    Oct 2015
    Status update got it down to 30hg and over a few minutes the vac leaked out. I then re vacd it down to 30 closed off the valves on both ports and it still lost vac at which point I knew the harbour freight gauges were leaking. Evacd back to ring and filled up with freon. Super cold a/c!! So that compressor was f*ckd
  18. #18 Re: Freon+working compressor= no cold air??
    St. Louis
    I hope you let it sit at 30Hg for a while (30-60 min is typical) to see if it held the vac, otherwise you may still have a leak somewhere.
    IIRC, the system holds 1.88lbs of Freon, which= 30.08oz, so about 2 1/2 12oz. cans should fill it up just right.
  19. #19 Re: Freon+working compressor= no cold air??
    Oct 2015
    Quote Originally Posted by FordMan77 View Post
    It did not hold pressure at 30hg but the gauges we were using were leaking so there was no for sure way to leak test the system. Considering we just installed a whole brand new system last October, put new seals/orings and it worked for 2 months before randomly not working one day me and my dad are very hopeful it was just the compressor.
  20. #20 Re: Freon+working compressor= no cold air??
    Nov 2012
    Madison
    Quote Originally Posted by suitercrew View Post
    You have to make sure. Moisture in a refrigerant system is a no-no. Could be why your compressor died.
    But anyway hopefully all works out for you
  1. Does low Freon shut off the compressor?
    By suitercrew in forum General Tech Discussion
    Last Post: 05-11-2017, 02:13 PM
  2. Help with freon leak 99 GTP
    By hshift in forum General Tech Discussion
    Last Post: 08-13-2016, 02:48 PM
  3. Freon/AC
    By jaydasparkz in forum General Tech Discussion
    Last Post: 07-21-2011, 05:28 PM
  4. Freon Charging
    By GreyGhost in forum General Tech Discussion
    Last Post: 03-27-2011, 04:30 PM
  5. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
