Thread: How to find leaky A/C line?
Results 1 to 4 of 4
  1. #1 How to find leaky A/C line?
    Donating Users
    Aug 2013
    Michigan, USA
    My A/C won't blow cold air. I checked the low pressure side was near zero so I recharged it to about 30. The next day it was back at zero so it seems I have leak but how do I find it? What are the most likely source of leak?
    2005 GP, NA
  2. #2 Re: How to find leaky A/C line?
    best way ive found to find them by eye is to look over all the lines and where they connect to each other. being it leaked out over night there will be a greasy/oily mess at the leak point.
    if you have extra r- what every. clean the pipe off good should you find a messy area, then re fill and see if its dirty the next day.
    the compressor can also leak so look at that close too.
    they do sell a dye kit for the a/c it will leave a red stain from the leak area. its a recharge kit with leak detector in it already.
  3. #3 Re: How to find leaky A/C line?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    the usual source for an a/c leak is the compressor shaft seal, it's right behind the pulley.
  4. #4 Re: How to find leaky A/C line?
    St. Louis
    Check both the schrader valves for leaks. Remove the plastic caps and see if one of them leaks. I just replaced the high side schrader on my 00 GT today and held 30 Hg just fine after that. Now it's nice and cold after the recharge.
  1. Leaky pcv
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2012, 11:09 PM
  2. Leaky valve cover gaskets...which ones to buy?
    By rell2005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2012, 02:42 AM
  3. Leaky ZZP FPR?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 08-31-2011, 07:53 PM
  4. leaky tail light lense
    By chumley in forum General Tech Discussion
    Last Post: 12-20-2010, 01:43 AM
  5. Leaky LIM
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2009, 02:23 PM
