Thread: why would knock retard go away over time
Results 1 to 16 of 16
  1. #1 why would knock retard go away over time
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    I have an ongoing issue with the kr on my car, im almost sure it is false, it happens when i stomp the throttle less than 3k rpm its ranges from 10-15 degrees depending on how fast i let off. I have noticed that if i let me car idle for a half hour or so the kr vanishes could there be an error in the pcm?
  2. #2 Re: why would knock retard go away over time
    Let me say this back to make sure I understand what you are saying.
    If you take the car out cold and romp it while the rpm are under 3K, you get 10-15 degrees of kr
    If you warm the car up first and them romp it, you don't get KR in the same areas under 3K rpm.
    You are making a change that isn't the pcm. You are allowing the car to be up to temp. Temp and other things can have an effect on the amount of timing. I would say the issue is in your tune or your foot.
  3. #3 Re: why would knock retard go away over time
    Oct 2011
    Toledo, OH
    Correct me if I'm wrong, but aren't the knock sensors disabled under 160 degrees anyway?
    7"
  4. #4 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    You are correct bill except it is at normal running temps when kr happens unless the car has been idling or driveing longer than half hour to 45min
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  5. #5 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    Industrial your correct but its not under 160 when it happens I let it get warm before I romp
  6. #6 Re: why would knock retard go away over time
    Thank you for clarifying. So the difference is not temp, it's only runtime.
    Have you considered that your car wakes up slow?
  7. #7 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    Yes runtime seems to be the key, no I haven't considered that, it doesn't slowly go away its either there or it isn't and when it is there its always 10-15kr
  8. #8 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    i wish someone had this problem before do you think a video of my gauges could help
  9. #9 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    bump
  10. #10 Re: why would knock retard go away over time
    Pennsylvania, USA
    Shot in the dark, but have you checked for vacuum leaks, like as soon as it gets into operating temperature? It could be that you have a leak that makes the engine run lean until the engine bay heat soaks and whatever is leaking swells and seals. Not sure if that could cause that much KR though...
  11. #11 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    ill take a look but my map is -21 at idle last time i checked and im not cammed so that should mean there is no vac leak correct?
  12. #12 Re: why would knock retard go away over time
    Fuel trims will tell you if a leak is there.
    Though -20 to -21 is good vacuum to have.
  13. #13 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    o2 is in the 920s 930s at wot
  14. #14 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    bump
  15. #15 Re: why would knock retard go away over time
    Narrowband readings are sorta okay, sorta not to follow when trying to figure stuff out.
    Those reading would be a guess of mid 11's for AFR, but a wideband is the best way to know.
  16. #16 Re: why would knock retard go away over time
    Jun 2013
    brookville,IN
    yea i really need to get a wide band, would anyone suggest buying a new o2 sensor for when i retune, ive heard that over time the o2 can change readings.
  1. seeing some knock retard
    By blakgtp in forum General Tech Discussion
    Last Post: 11-05-2012, 11:02 AM
  2. New Knock Retard
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-19-2012, 09:22 AM
  3. knock retard
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-19-2012, 11:41 AM
  4. 5* of knock retard at WOT please help
    By asite57 in forum General Tech Discussion
    Last Post: 06-15-2012, 08:45 PM
  5. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
