Thread: Screeching from wheel
Results 1 to 9 of 9
  1. #1 Screeching from wheel
    Dec 2012
    Oswego, Illinois
    Hello all! Not quite sure what is wrong, so maybe someone can shed some light on this for me. While I'm driving close to a median/curb I can hear a screeching coming from my wheel. At first I thought it was my brakes needing to be changed. After replacing them, the noise still occurs. Anyone had a similar problem and know what it could be?
    Sent from my ADR6400L using Tapatalk
    2002 GTP: My Daily
    Wizaired CAI
  2. #2 Re: Screeching from wheel
    Nov 2011
    NY
    Are you driving on the paint? Depending upon the tread design, you might get a different pitch of sound when on the flat surface from the paint.
  3. #3 Re: Screeching from wheel
    Dec 2012
    Oswego, Illinois
    No, I've noticed it even when driving on some roads out here in my town that don't have paint
    2002 GTP: My Daily
    Wizaired CAI
  4. #4 Re: Screeching from wheel
    jack up both front wheels, put it in neutral and see how the wheel spins vs the other one. also check for play by pushing and pulling the top of the tire. if it moves the hub is bad.
    my left front hub is failing to spin freely, no sounds yet but i feel it making the car pull a bit and it the car feels heavy as soon as i let off the gas. so im doing a hub tomorrow it seems.
  5. #5 Re: Screeching from wheel
    Dec 2012
    Oswego, Illinois
    Thank you, will look into it. My moms boyfriend said he'd replace my wheel bearings for me last month and ever since then I've had nothing but problems. Never doing that again lol
    2002 GTP: My Daily
    Wizaired CAI
  6. #6 Re: Screeching from wheel
    what a wheel hub? those are easy peasy. ill have mine done in like a hour or so with the trip to the parts store included. this will be my third time doing a front. not to bad really.
  7. #7 Re: Screeching from wheel
    Dec 2012
    Oswego, Illinois
    I notice it when I'm turning as well
    2002 GTP: My Daily
    Wizaired CAI
  8. #8 Re: Screeching from wheel
    Mar 2014
    SE PA
    Check that the backing plate isn't rubbing the back of the rotor. I had a screeching problem and thats what it turned out to be.
  9. #9 Re: Screeching from wheel
    St. Louis
    Either that or check that the brake pad clips aren't bent and stuck up under the caliper. Just saw this issue and everything braking-wise was fine, but had a faint metal on metal sound.
  1. Belt Screeching
    By ILoveAudi in forum General Grand Prix Discussion
    Last Post: 09-24-2013, 01:37 PM
  2. Screeching Sound, But Not From Belt
    By LeoD in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2013, 11:48 AM
  3. Screeching sound, but not from belt
    By LeoD in forum Introductions/Noob Questions
    Last Post: 02-26-2013, 01:51 AM
  4. Brakes screeching
    By Steven Monteith in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2012, 12:56 AM
  5. New CV axle, Now loud screeching...
    By Greinerts in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2009, 12:58 AM
